Author: Subject: filters filters filters ???
givemethebighammer
posted on 13/4/04 at 08:35 PM Reply With Quote
Right, on my travels through locostworld I have aquired 3 sets of air filters.
1. ITG JC20 base plates and 40mm internal \ 65mm overall height filters (new)
2. 2 x Pipercross dual sock filters (new)
3. 4 x pipercross individual sock filters (used)
So which do I use on my twin 45's on my 2.0L zetec and which do I sell on ?
I like the look of the ITG ones however their small height concerned me with regard to air flow. Although the ITG filters can breath through the front panel as well as the sides (unlike a K&N).
The Pipercross dual socks are as tall as the equivalent K&N but the push fit doesn't inspire confidence they will stay put.
and the single socks as for dual socks
or should I sell the lot and buy some shiny K&N ones ?
A couple of people are going to get a cheap set of filters. Just don't spin me one so I sell the best ones !!!!
(As if you would even consider doing that !!)
macspeedy
posted on 13/4/04 at 08:42 PM Reply With Quote
the itg i went for they flow from the front and the sides and look the part!
givemethebighammer
posted on 13/4/04 at 08:44 PM Reply With Quote
so the small height of the ITG doesn't restrict the flow compared in anyway ?
macspeedy
posted on 13/4/04 at 08:49 PM Reply With Quote
as long as they are a distance a remember being specified on itg website you should be ok
SeaBass
posted on 13/4/04 at 09:51 PM Reply With Quote
You seem to see ITG filters all day long at Hill Climb meets, they must know something. Having said that I thought they were a tad expensive and the only people who seemed to sell them was Merlin Motorsport.
Dave Ashurst
posted on 13/4/04 at 10:50 PM Reply With Quote
If you use foam type filters - either ITG or PiperX - then don't forget to treat them with the proper tacky filter oil. Otherwise (and probably even still then) the holes are too coarse to stop all the abrasive airborne particles.
Without the oil I don't think they do anything like enough filtering.
zetec
posted on 14/4/04 at 07:45 AM Reply With Quote
if you are using trumpets on the webers suspect the itg unit will not be high enough.
MK7
posted on 30/4/04 at 04:50 PM Reply With Quote
U have U2U
I'm interested in the JC20 if it end up being for sale
macspeedy
posted on 30/4/04 at 05:05 PM Reply With Quote
just for reference use
