Author: Subject: Trigger wheels
norfolkluego
posted on 10/12/09 at 12:11 PM Reply With Quote
Trigger wheels
No experience with said chappies and I'm about to fit one to the Zetec, do they just bolt on to the front of the crank pulley, I'm just a bit worried it might just catch the water pump pulley or do you fit a spacer or is there another way?
Also, how heavy are they normally, the one I bought off eBay seems to be made of quite thick steel and is pretty heavy.
blakep82
posted on 10/12/09 at 12:15 PM Reply With Quote
i've got a vauxhall engine, but mine is just bolted to the pulley, no spacers or anything. can't help on your water pump though.
they need to be quite thick to make sure the sensor gets a good signal. i wouldn't worry too much about the weight. they're only small. go for a leak before you go for a drive. weight saved
________________________
Myke 2463
posted on 10/12/09 at 12:22 PM Reply With Quote
If your using 1.8 or 2.0 lt flywheel why not use the original sensor and save problems ?
mcerd1
posted on 10/12/09 at 01:14 PM Reply With Quote
second that, there's no need if your using the standard flywheel
in fact you can see where the sensor goes in your own pic
Sump1
Sump1
the trigger wheels are normally 5 or 6mm thick, they need to be a bit thick to get a good reliable signal (also they have to be steel/iron, if you made an alloy one it wouldn't give you a signal )
if your after light weight you want a ring type one, but you need something to mount them to like this: linky (but you don't want to know how much that cost )
[Edited on 10/12/09 by mcerd1]
whitestu
posted on 10/12/09 at 02:43 PM Reply With Quote
I used a 1.8 CVH flywheel on my Blacktop zetec so I welded a trigger wheel from the CVH onto the Zetec crank pulley.
Stu
Barronge
posted on 10/12/09 at 04:48 PM Reply With Quote
I was told you didnt need one on a Zetec...... im hoping you dont cos i havent got a clue what one is???
whitestu
posted on 10/12/09 at 06:37 PM Reply With Quote
Zetecs have a 36:1 trigger drilled into the flywheel, so only needed if you aren't using a zetec flywheel.
Bike curious
posted on 10/12/09 at 08:38 PM Reply With Quote
Hi, I fitted a 36 tooth, 1 space type trigger wheel onto my Reliant engine which came from triggerwheels.com and just bolted it on.
Choose one slightly bigger than the crank pulley and make sure it's mounted centraly, mine was turned down in a lathe slightly after fitting to make sure it was concentric with the pulley. Important as the sensor needs to run within 1mm of the trigger wheel.
norfolkluego
posted on 10/12/09 at 08:52 PM Reply With Quote
In the best Colin Chapman tradition (we are from Norfolk after all), we're adding lightness, so we have a CVH flywheel (3 kgs lighter than standard) so no timing marks, hence the need for a trigger wheel
Barronge
posted on 11/12/09 at 01:37 PM Reply With Quote
Cheers, thats answered my query
L5W
posted on 15/12/09 at 09:27 PM Reply With Quote
I'm planning to use the same method of using the cvh flywheel and a trigger wheel at the front on my zetec with the type 9.
Is QH CCT133 the correct release bearing to use along with a cvh clutch to make this work? I've seen the QH CCT132 bearing mentioned before and want to make sure I have the correct one
Thanks,
Lee
