marcotuinenburg
| posted on 16/4/04 at 01:55 PM |
How much oil needs my Sierra diff. ?
Hello,
When i was painting my diff all the oil leaked out. Now that wasn't a problem but i'm now at the stage of mounting the rear axles and i
don't now how much oil the diff needs. It's a standard Sierra diff. And what kind of oil does it need. Is Transmission oil also oké ?
Marco Tuinenburg
theconrodkid
| posted on 16/4/04 at 02:45 PM |
it will take about 1 litre of ep80/90 oil,when it,s mounted just fill till it comes out the filler plug and thats it
who cares who wins
pass the pork pies
| posted on 16/4/04 at 02:46 PM |
0.8 or 0.9ltr depending on model from dry or 10mm below filler hole otherwise. Oil grade is hypoid sae90ep.
[Edited on 16/4/04 by Peteff]
givemethebighammer
| posted on 16/4/04 at 06:30 PM |
just did mine - took 0.9 litres before it started to dribble out of the filler hole.
incidently, I drained my diff of the old oil using a marine oil change pump I bought from the local marina supplies. Easiest way I have ever found of
removing the oil from a diff or gearbox. Pump was Ł7, image below.
marcotuinenburg
| posted on 18/4/04 at 09:59 AM |
Oké, and the fillerhole is that the big bold on the diff or is it the small pipe at the top of the diff ?
theconrodkid
| posted on 18/4/04 at 01:55 PM |
its the plug on the back of the diff,small hose is breather
who cares who wins
pass the pork pies
