Author: Subject: dipstick interference fit question
givemethebighammer
posted on 16/4/04 at 06:34 PM Reply With Quote
Does the dipstick require and sealant or grease on the interference connection to the engine block ? (Zetec engine, but sure Pinto is the same)
NS Dev
posted on 16/4/04 at 10:06 PM Reply With Quote
you mean the dipstick tube into the cast block? If so then I usually use loctite to seal and fix it in.
givemethebighammer
posted on 16/4/04 at 10:28 PM Reply With Quote
yes, that's the one. I have red coloured stud lock and blue coloured thread lock (I know the colour is not important). Which one do I use ?
thanks
spunky
posted on 16/4/04 at 10:34 PM Reply With Quote
Whichever suits you best, both will do the job. IMO
John
NS Dev
posted on 16/4/04 at 10:40 PM Reply With Quote
Not that it is life and death but I would use the stronger one as you don't need to take it out again, the red studlock one.
givemethebighammer
posted on 16/4/04 at 10:42 PM Reply With Quote
problem solved, stud lock it is then.
thanks people.
