flak monkey
posted on 18/12/09 at 08:27 PM |
Saab clutch cylinder connections
Which connections is which on the clutch slave cylinder? Anyone know?
TIA
![](/galpreviews/a1063829-m_P1010080.jpg) ![Rescued attachment m_P1010080.jpg](/gallery/a1063829-m_P1010080.jpg) Rescued attachment m_P1010080.jpg
Sera
http://www.motosera.com
posted on 18/12/09 at 08:38 PM |
Check the bottoms of the holes , if they are the same it doesn't matter, if not then the bleed nipple/pipe needs to seal
flak monkey
posted on 18/12/09 at 08:50 PM |
Both appear to be the same, concave seats as normal
Sera
907
posted on 19/12/09 at 08:30 AM |
Hi David,
When it's bolted to the g/box then which ever one is nearer to the top (TDC) must be the bleed I would have thought.
Air will collect at the top after all.
I can't be of more help as I used the Mundano one in my Getrag.
This had a long pipe on it with the bleed nipple on the end, which just pokes though a hole I drilled in the bell housing.
Lucky eh!
Paul G
