<<  1    2  >>
Author: Subject: Best place to get a Zetec exhaust manifold?
norfolkluego
posted on 12/1/10 at 11:45 AM Reply With Quote
I was going to get one from er.... a supplier but was told at the last phone call 'there are a few issues at the moment, best look elsewhere' (no money had changed hands), where's the best place for my money to go, I've seen Westfield do them, anyone else and a bit cheaper wouldn't go amiss
cd.thomson
posted on 12/1/10 at 11:51 AM Reply With Quote
GBS/Robin hood do a cheap one but it isnt fantastic quality. does the job though!
Craig
scutter
posted on 12/1/10 at 11:54 AM Reply With Quote
If you can weld, I think Great British Sportscars do the cheapest. LINKY Bugger beaten to it.
ATB Dan.
[Edited on 12/1/10 by scutter]
posted on 12/1/10 at 12:15 PM Reply With Quote
Save your self some money and grief, get a decent one made for your car . I had loads of problems with my manifold from Lolocost/GBS and ended up getting one made from decent stainless. Not cheap but well happy with it. You get what you pay for?
fatbaldbloke
posted on 12/1/10 at 12:26 PM Reply With Quote
Top end, both price and quality - Simpson Race Exhausts.
scutter
posted on 12/1/10 at 12:27 PM Reply With Quote
Just remembered that 907 is over the border in suffolk, why not drop him a line.
Dan.
mad4x4
posted on 12/1/10 at 12:31 PM Reply With Quote
Custom Chrome in Nuneaton do the Plate
sorry don;t have link but call
02476387808
Scot's do it better in Kilts.
posted on 12/1/10 at 12:34 PM Reply With Quote
You have u2u. Mel
DavidW
posted on 12/1/10 at 12:44 PM Reply With Quote
I have the GBS one but expect I'll proabably end up getting a better one - should have saved myself money by buying a propoer one first time....
Danozeman
posted on 12/1/10 at 12:48 PM Reply With Quote
Mines a fisher fury one. Not bad quality and not bad price.
Dan
whitestu
posted on 12/1/10 at 12:56 PM Reply With Quote
Westy ones are nice.
smac
posted on 12/1/10 at 03:26 PM Reply With Quote
Anyone fitted a westy one in a book chassis?
Danozeman
posted on 12/1/10 at 04:28 PM Reply With Quote
IIRC you need to move the diagonal crossmember to fit a westy one.
heres the fisher one
Heres mine with a one fo 907's silencers. Depends how much eaxhaust you want to see.
car side
car side
[Edited on 12/1/10 by Danozeman]
Dan
eddie99
posted on 12/1/10 at 05:07 PM Reply With Quote
I bought a GBS one, it will do the trick but in the end, it will be replaced. If you can, get a good one to start with and save yourself some grief
Steve G
posted on 12/1/10 at 05:32 PM Reply With Quote
And probably gain yourself some power!! A decent tuned exhaust should be one of the cheapest ways to gain some power imho. As above from various people, spend a little extra and best to do it right first time around.
smac
posted on 12/1/10 at 07:39 PM Reply With Quote
I ve read before that of the cheaper ones ( although how £300 can be called cheap) the westfield one is good for power - something to do with the collector I believe. Im building up to parting with the cash.
[Edited on 12/1/10 by smac]
mr T
posted on 12/1/10 at 09:39 PM Reply With Quote
Look Here
scutter
posted on 12/1/10 at 10:18 PM Reply With Quote
The Tiger downpipes are ok, but they still need a £120 collector!
Dan.
norfolkluego
posted on 12/1/10 at 11:49 PM Reply With Quote
That's why I don't really want to go with the Westfield one, don't want to start chopping bits out of the chassis, the GBS one goes over the top rail which is why I liked the look of that one but that's now off the shopping list
MikeR
posted on 13/1/10 at 09:16 AM Reply With Quote
What is so bad with the GBS one?
DavidW
posted on 13/1/10 at 10:00 AM Reply With Quote
Mine seems to rely on slightly oval holes in order to line up on the head.
I think it needs some tweaking to line up properly.
norfolkluego
posted on 20/1/10 at 06:51 PM Reply With Quote
Anyone have any experience of these
http://cgi.ebay.co.uk/LOCOST-VINDICATOR-SEVEN-ZETEC-4-1-EXHAUST-MANIFOLD-KIT_W0QQitemZ320445629605QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM ?hash=item4a9c0c44a5
I'm getting quoted some horrendous prices for making a stainless one up (over £500)
scutter
posted on 20/1/10 at 07:33 PM Reply With Quote
I'd say that's worse than the GBS one, at least there's is bent pipes not straight sections for you to weld together.
£500 seems about right for a custom one, i was quoted that for mine about 5-6 years ago.
ATB Dan.
posted on 20/1/10 at 08:38 PM Reply With Quote
Don't know about the Zetec manifold but if it's anything like their Xflow item then flanges so badly distorted the only way I could get it to seal against the head was to cut the flange plate into 3 separate pieces . Even then the manifold had to be bolted to a spare head with a couple of blocks of wood inserted so that the pipes could bend enough to get a seal . Flange not fully welded so that after managing to seal the flange I had to remove the manifold and reweld parts of it. Poor quality stainless that rusted almost as bad as mild steel . In it's defence it was cheap but you get what you pay for. Many thanks to Paul (907) for his excellant work making the new manifold.
Andybarbet
posted on 20/1/10 at 09:10 PM Reply With Quote
If they are still around, try 'Tube engineering' - they were in Peterborough area and i got mine direct from them (about 3 or 4 years back) as they used to make them for old luego.
I payed very little for mine & the silencer, considering what old luego were charging with their mark up. The guy also polished it for me for a tenner extra
Very good to deal with too.
<<  1    2  >>
