Author: Subject: Are the gearbox ratios from a 2.0ltr pinto type 9 box different to the gearbox ratios from a type 9 box that came from a 1.8 cvh
rich201283
posted on 21/4/04 at 01:10 PM Reply With Quote
Are the gearbox ratios from a 2.0ltr pinto type 9 box different to the gearbox ratios from a type 9 box that came from a 1.8 cvh?
flak monkey
posted on 21/4/04 at 02:13 PM Reply With Quote
A contender for the longest subject title i think
And the answer to your question...no afaik. The only difference would probably be in the fianl drive ratio..ie the diff ratio.
I stand to be corrected .....
Sera
http://www.motosera.com
posted on 21/4/04 at 04:08 PM Reply With Quote
As above if the 1600 and 2 litre were the same they ain't going to change them for the 1800.
Mark Allanson
posted on 21/4/04 at 06:37 PM Reply With Quote
I did a fair bit of research on this when I was starting off, as far as I could find out ALL type9's had the same ratio's
1st 3.65
2nd 1.97
3rd 1.37
4th 1
(5th) 0.82
NS Dev
posted on 21/4/04 at 10:04 PM Reply With Quote
not all the type 9's had the same ratios, but as far as I know all the 4 cylinder petrol ones did! certainly the XR4x4 with type 9 'box was different, closer ratios. Diesel 2.3 was different too.
Avoneer
posted on 21/4/04 at 10:14 PM Reply With Quote
Mine is a 3.92. Pressume this is the 1st gear ratio. It is on the metal tag on the back. I'm sure there are more than the two mentioned as well.
Pat...
ned
posted on 22/4/04 at 09:03 AM Reply With Quote
I think you're talking crossed purposes. afaik all 4 cylinder t9's had the same ratio's. the v6 type 9 with a longer input shaft had a longer first gear. the diesel and 4x4 and 3.92 you mention are prob the differences in the dif at the rear of the car.
Ned.
[Edited on 22/4/04 by ned]
beware, I've got yellow skin
Avoneer
posted on 22/4/04 at 12:01 PM Reply With Quote
Yeah, sorry, just ignore me and I'll go away. I'm a bit confused......
I was talking about diffs for some reason...
Pat...
