| posted on 16/1/10 at 03:37 PM |
who likes 3D puzzles?
with vraious bits of shaped silicone hose, I have at least 3 possible thermostat to radiator layouts, as below.
I will attach picture with each posst - there are 3 so be patient until you have seen them all before making commments.
this one is my favourite.
| posted on 16/1/10 at 03:39 PM |
next one is this one; since it rises a bit, it may not have enough clearance under the bonnet ... but may since the pieces can be cut further to
shorten them.
| posted on 16/1/10 at 03:41 PM |
and finally. this one uses original thermostat whereas the 2 above use a modified one; so there should be no issues of 'stat failure.
not liking this one since the hoses sit over the exhaust.
| posted on 16/1/10 at 03:43 PM |
so which do you reckon is best and why?
all three layouts should give enough flex between engine and radiator.
dlatch
| posted on 16/1/10 at 03:45 PM |
i would go for 2 as it just looks the most right
iank
| posted on 16/1/10 at 03:46 PM |
2 looks best to me as well. should lose a couple of inches out of the loop when it's cut down.
Anonymous
mookaloid
| posted on 16/1/10 at 03:49 PM |
For no really good reason I think I like no 2 best -it looks neater
| posted on 16/1/10 at 03:50 PM |
1 would block off more air flow at teh rear.
with 2, there seems to eb a lot of clearance between the 2 hoses, hmmm, not sure that is right since radiator is able to mave as well as the
thermostat not being bolted down but looking at them, I am favouring 2.
prelude1980
| posted on 16/1/10 at 04:08 PM |
just a question as i can't really tell the difference between connection but can't you just use a 90 deg reducing elbow?
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
cliftyhanger
| posted on 16/1/10 at 04:20 PM |
it may be possible, but it would not be a good idea as there would not be enough hose to allow for engine movement. So fairly soon stress fractures in
the rad etc.
Oh, and I too like second one, keeps hoses away from belts, easier to do up hose clips etc.
mistergrumpy
| posted on 16/1/10 at 04:32 PM |
2 too
prelude1980
| posted on 16/1/10 at 04:42 PM |
the rad etc.
Ah didn't think of stress cracks
In that case no.2
gets you.
ReMan
| posted on 16/1/10 at 04:49 PM |
2 4 me
speedyxjs
| posted on 16/1/10 at 04:57 PM |
2
| posted on 16/1/10 at 05:13 PM |
I had suggested that a while back but the hosed would be very short; it would not allow much give for any engine movement.
connections are:
1. stat -> 38mm/32mm 90 deg reducer - 32mm U - 32 mm 90 deg
2. stat -> 38mm/32mm reducer - 32mm U - 32 mm 90 deg
3. stat -> 38mm/32mm reducer - 32mm U - 32 mm 45 deg
Chippy
| posted on 16/1/10 at 05:51 PM |
I would go for 2 as well, just for the looks, but reduce the lengths of the hoses just a bit. Although for best articulation I think 1
would be the best, as it allows for more movement. Cheers Ray
