Author: Subject: Fan switch
givemethebighammer
posted on 23/4/04 at 03:36 PM Reply With Quote
Fan switch
I have connected a nissan micra rad to my zetec engine, question now is do I use the fan switch in the rad or the one on the thermostat housing ?
Berwyn
posted on 23/4/04 at 03:59 PM Reply With Quote
I'd go for the one in the thermo housing as that is going to switch at the temp ford intended. I dont know what temp the ford will switch at but the micra trips at 95-100 degrees.
24 hours in a day, 24 beers in a case. Coincidence? I think not
Mk-Ninja
posted on 23/4/04 at 04:10 PM Reply With Quote
Ive used a micra rad and used the switch in the rad. Works fine.
I'm sure I've got one, just don't know where I've put it
posted on 23/4/04 at 05:44 PM Reply With Quote
I used both the one in the thermostat housing AND the one in the Polo rad! They're wired in parallel, so the fan will come on if either one operates.
The reason for this was that I wanted a blanking plug for the rad hole, and the standard switch was cheaper!
rgds,
P.S. Both operate at 85C
[Edited on 23/4/04 by David Jenkins]
Mark Allanson
posted on 23/4/04 at 07:44 PM Reply With Quote
if you want to use the switch from the Sierra, get a hose off a 1.8TD, the switch is in a reinforced brass plate about half way up.
Markp
posted on 23/4/04 at 10:59 PM Reply With Quote
I know you can have different temperature settings for the ford thermostat housing, mines about 83 degrees, Intermotor do various types.
But I would use both as a fail safe.
Mark.
[Edited on 23/4/04 by Markp]
zetec
posted on 24/4/04 at 05:07 AM Reply With Quote
If you are fitting an ECU then that might well have a fan output. Mine uses the temp sensor and switches the fan at whatever temp you type in. Mines set for on 99deg-off 95deg. Fit a new Ford thermostat and you will find it runs at just over 90deg only rising when stopped in traffic.
