Author: Subject: Where did this plug come from?
scudderfish
posted on 29/1/10 at 11:34 AM Reply With Quote
I've got this plug on my TPS. Does anyone recognise it? What do I need to plug into it? Or do I just chop it off and put something else on?
Regards,
Dave
Danozeman
posted on 29/1/10 at 12:00 PM Reply With Quote
id cut it off and put something else on there,
Dan
posted on 29/1/10 at 01:18 PM Reply With Quote
+1. Bizarre looking thing. Most TPSs use the mini timer type connectors.
scudderfish
posted on 29/1/10 at 01:20 PM Reply With Quote
Ta, I'll whip it off then.
Canada EH!
posted on 29/1/10 at 02:53 PM Reply With Quote
Question, does the motor run with out it connected? Would check first.
RAYLEE29
posted on 29/1/10 at 03:55 PM Reply With Quote
bit more info might help i can see its a rv8 with on offy 360 but what tb is it? does the other end of the wires plug onto the tps or somewhere else it looks like the plug for a camshaft sensor or a tdc sensor but doesnt look like any ive seen before
Ray
ps I wouldnt cut it off till i knew what it was for
cd.thomson
posted on 29/1/10 at 04:03 PM Reply With Quote
its the tps wiring raylee.
Craig
scudderfish
posted on 29/1/10 at 04:10 PM Reply With Quote
It's definitely from the throttle position sensor. The manifold is an offy 360, and the TB is a 4 barrel device a bit like a stripped down carb. I've yet to wire it all together as part of my carbs -> Megasquirt/EFI project. If someone said "Oh yes, you can get them from xyz.co.uk for £2" I'd be interested in buying one, but if it's a special order from the US for £20 + $50 shipping then I'll get the wire cutters out
twinturbo
posted on 29/1/10 at 07:20 PM Reply With Quote
Ford used that plug on a few things.
2.0DOHC IAT I think... Altough it was white in that applicatuion from memmory.
TT
