List of engine/trans wiring elements
Hey all - I'm trying to devise a list of all the wiring elements that I will need to take into consideration when doing the motor installation,
and here's what I have so far (broken into Engine and Chassis looms):
Motor:
+/- Terminals of Battery
Starter Motor + Solenoid
Fuel Pump(s)
EFI controls
-02 Sensor
-MAF/MAP
-Ignition + timing (control if variable valve timing)
-TPS + Idle TB control
Brake booster
Oil Sump
Water pump
Radiator fans + switch
Thermostat
Alternator
Speedo (if electrical)
Tach (if electrical)
Fuel sender
Knock sensor (if any)
Body:
Lights
-Turn Signals
-Brake Lights
-Hazards
Wipers + spray jets
Accessories (stereo, Interior lights, dash lights)
12V power outlet
Halon system (I will be using one, safety first)
Horn
Climate Control (heater, no A/C)
What am I missing? Would there be wiring connections on the manual transmission?
This list is mainly to help in the task of installing an AWD or RWD motor into my Honda CRX, but I thought that it would also help as a guide for the
wiring-inept (such as myself)
Thanks a ton - I know I can count on you all (best forum on the 'net!)
-MR
