andy188
| posted on 4/2/10 at 05:50 PM |
1800cvh head with zetec bottom end
Hi, has anyone fitted a 1800 cvh head to a 1800 zetec bottom end, just keeping my options open for engine upgrade, seems to be a short supply of pre
95 zetec engines in my area, any info greatly appreciated
big_wasa
| posted on 4/2/10 at 06:01 PM |
That would not be an upgrade.
You would be better with an early hemi head if doing a zvh.
Better still to use the zetec head.
UncleFista
| posted on 4/2/10 at 06:02 PM |
If you filled in your profile and told us what area you're in, you might get a bit of help
But, I wouldn't have thought bolting any cvh parts to a Zetec could be classed as an "upgrade"
Tony Bond / UncleFista
big_wasa
| posted on 4/2/10 at 06:24 PM |
Location................
here
you go 93~94 1.8 zetec for less than £50
mangogrooveworkshop
| posted on 4/2/10 at 06:35 PM |
zvh is a waste of energy
Its a bodge that works but will drive you nutz with reliability stakes....cvh is more of a boat anchor than a pinto
andy188
| posted on 4/2/10 at 07:52 PM |
Hi, thanks for advise, have filled in some off my profile (sorry, still learning), thanks for ebay engine, reasonably close to me, thanks andy
whitestu
| posted on 4/2/10 at 09:21 PM |
An 1800 CVH is perfectly good enough to start with and makes IVA easy. Assuming it is a carb engine then fuel and ignition are all sorted.
Once passed, upgrade to a Zetec. That way you can fit a Zetec as new as you like with bike carbs and megajolt or TBs and megasuirt.
The upgrade from a 1.8 cvh to Zetec is pretty straightforward.
I had a 1.8cvh in mine to start with and it went well enough, and weight is similar to a Zetec.
Stu
[Edited on 4/2/10 by whitestu]
