Author: Subject: Ford type 9 box- how to find ratios
alistairolsen
posted on 6/2/10 at 11:56 AM Reply With Quote
I have an unknown type 9 box and Id like to find out which version it is, where should I be looking for plates or stampings?
My Build Thread
Steve G
posted on 6/2/10 at 12:38 PM Reply With Quote
As far as i know there's only 2 versions - with the standard and long input shaft versions that were fitted to the 2.8 cars.
omega0684
posted on 6/2/10 at 12:44 PM Reply With Quote
Already covered this month,
Looky Here
alistairolsen
posted on 6/2/10 at 01:58 PM Reply With Quote
so all type 9s are the same ratios?
What length are the short and lon input shafts respectively?
My Build Thread
mookaloid
posted on 6/2/10 at 02:44 PM Reply With Quote
er no the previous thread shows that the long input shaft boxes have a higher ratio 1st gear
cliftyhanger
posted on 6/2/10 at 03:31 PM Reply With Quote
I don't think so!
I believe there are some long input shaft boxes with the less helpful ratios. Diesels? P100?? but never assume long input=close ratio!
I guesss the best way to check is put it in gear and count the turns?
posted on 6/2/10 at 03:42 PM Reply With Quote
If it's any help the bell housing on the short box is 7" from the gearbox mating surface to the engine mounting surface,
