Author: Subject: New intercooler fitted
t16turbotone
posted on 10/2/10 at 07:56 PM Reply With Quote
Just fitted MR2 alloy intercooler hopefully it will do the trick Rescued attachment int2.jpg
oadamo
posted on 10/2/10 at 08:00 PM Reply With Quote
how are you getting air to that.
adam
INDY BIRD
posted on 10/2/10 at 08:02 PM Reply With Quote
interesting place to put an intercooler?
do you think this will be efficient enough there, ie can you get enough air through it?
Would need a good scoop to drive the air into it in that location,
Can you not mount this towards the nose cone area??
good luck though
t16turbotone
via a bonnet scoop....next job!
omega0684
posted on 10/2/10 at 08:08 PM Reply With Quote
tony can you not get it in front of the rad and route the pipes around the edges?
oadamo
posted on 10/2/10 at 08:13 PM Reply With Quote
you would be better off with a charge cooler there, ill put money on it that you wont get enough air there to make it worth it even with a bonnet vent.
adam
t16turbotone
posted on 10/2/10 at 08:18 PM Reply With Quote
in short...yes i could do that, however i would need to change inlet manifold to a landrover mpi discovery item, and quite a lot more ducting. There is a fan behind intercooler which isnt in view.
I know what you mean guys, but i was running with no intercooler at all! i got the intercooler of ebay for £40. I will do some datalogging and see if IAT is any lower
[Edited on 10/2/10 by t16turbotone]
Danozeman
posted on 10/2/10 at 08:43 PM Reply With Quote
if you get a ducted scoop to it and the fan is a sucker then it shoud be ok.
Dan
bilbo
posted on 10/2/10 at 10:24 PM Reply With Quote
Looks good to me Tony, provided you can duct some air too it.
I only know too well what a PITA it is to find a good position for an Intercooler for these engines
As said, only practical way to put it in front of the rad is to get a landrover manifold, or cut and shut the existing one.
In the end, I opted for a charger cooler. Still been a pain to plumb though - time will tell if it actually works.
Let us know how you get on with this set up.
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
hicost blade
posted on 10/2/10 at 10:37 PM Reply With Quote
Get a 7.5" fan and duct some air from somewhere cold and you shouldn’t need a scoop
Dale
posted on 10/2/10 at 10:52 PM Reply With Quote
Similar positioning of mine- just waiting on deliverory of the silicon adaptors.
I have been trying to sort out hood scoop vs ducting in from the side or bottom. Problem with a hood scoop is that it has to be high enough off of the bonnet to get past the boundry layor of air along the bonnet. I think that normally would be a minimum of 3 to 4 inches off the surface. Ducting out the side of the bonnet or down through the trans tunnel is an option as well.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
GeoffT
posted on 11/2/10 at 10:49 AM Reply With Quote
Just out of interest, what sort of IAT's were you getting without the intercooler?
t16turbotone
posted on 11/2/10 at 01:36 PM Reply With Quote
after good run, IAT reached as much as 72 degrees, power falls off radip at these temps
boggle
posted on 11/2/10 at 04:34 PM Reply With Quote
get a cryo system fited to spray co2 onto the intercooler at around 60 degs.....bonnet scoops are a waste of time, you will get a warm air depression under the bonnet where the cool air coming in from the nose cone warms up from the rad and the cool air coming in from the scoop hits it.....you would need vents at the back of the bonnet to releas it.........
u2u me for details
dlatch
posted on 11/2/10 at 05:52 PM Reply With Quote
front mount or charge cooler imo
anything else is ultimatley a bodge
ask any scooby owner
t16turbotone
posted on 11/2/10 at 07:08 PM Reply With Quote
Thanx for the replies, maybe sometime soon i will tig weld a box section around the intercooler with a couple of outlets and convert it to chargecooler
