Author: Subject: Daft question about Bike carbs
mad4x4
posted on 19/2/10 at 12:47 PM Reply With Quote
If I take a bike carb and remove the slider and the Fuel side of the carb does it become a "thorttle body" in principle?
Surely a throttle body is a Tube with a butterfly at one end....
as per Linky to Flea Bay
Scot's do it better in Kilts.
posted on 19/2/10 at 12:49 PM Reply With Quote
You will have to fit the injectors somewhere...
mad4x4
posted on 19/2/10 at 12:51 PM Reply With Quote
Its a zetec head so I still have the sandwich plate for the injectors.
blakep82
if you fit injectors into your manifold, then i don't see why not.
________________________
Danozeman
In theory yes but you wont have a smooth body all the way through as youl have the gap where the slide goes. And as David says you will need a manifold with injector holes.
Dan
blakep82
posted on 19/2/10 at 12:55 PM Reply With Quote
don't want to take this down the wrong way, but on a bike carb, what does the slide actually do?
cd.thomson
posted on 19/2/10 at 01:02 PM Reply With Quote
like this but the slide is generally operated by the engine vacuum in our carbs with the throttle cable controlling the vacuum via the butterflies.
[Edited on 19/2/10 by cd.thomson]
Craig
big-vee-twin
posted on 19/2/10 at 01:09 PM Reply With Quote
You can mount the bodies onto a ST170 manifold like this and use the injector pockets in the manifold.
http://www.triangleltd.com
r1_pete
The slide controls the effective venturi size to maximise air velocity across the rev range, i.e.
low revs, small venturi = high gas speed
As revs rise the decrease in pressure in the manifold, allows air pressure under the diaphragm to lift the slide and allow more air in. The drilling to the engine side of the diaphragm seal is connects to the venturi, hence at manifold pressure, the holes at the inlet side of the carb are to keep the underside of the diaphragm at atmosphere.
Stripped carbs have been used as TB's before though, so perfectly possible.
[Edited on 19/2/10 by r1_pete]
whitestu
posted on 19/2/10 at 02:03 PM Reply With Quote
That's what I'll be doing if I ever go EFI. I've already re-spaced a set of ZX6 carbs and have modified a Mondeo plastic manifold, complete with injectors, to bolt them to.
Stu
Danozeman
posted on 19/2/10 at 05:49 PM Reply With Quote
why not just buy these?
linky
perfect for the job.
Dan
blakep82
posted on 19/2/10 at 06:59 PM Reply With Quote
wow, who had the imagination to come up with that?!
mad4x4
posted on 23/2/10 at 12:53 PM Reply With Quote
Ok first attempt will be to convert the Bike carbs into throttle bodies. I won;t remove the slider but lock it UP to give a smoother body... and plug some of the wholes......
mad4x4
posted on 23/2/10 at 12:55 PM Reply With Quote
Alternately what about leaving the the Slide active to the effective venturi size to maximise air velocity across the rev range... so EFI with variable Venturi.....
sebastiaan
posted on 23/2/10 at 04:19 PM Reply With Quote
Yes! that is exactly what you should try to do. The 5PW (i think..) R1 uses exactly this setup, CV throttle bodies.
It should help better atomize the fuel and burn speed (by having a more homogeneous mixture), minimizing ignition advance needed for maximum torque at lower revs.
Could you post a picture of the inside of the carbs with throttle plate and slide held open so we can have some idea of what still protrudes into the airstream?
