oadamo
posted on 20/2/10 at 08:20 PM |
200 mph gearbox?
what gearbox is capable of 200mph+ off a standard car thats cheapish.
adam
philw
posted on 20/2/10 at 08:27 PM |
T5
Must try harder
liam.mccaffrey
posted on 20/2/10 at 08:34 PM |
The answer depends on engine torque and power. The power and torque the box will see due to grip and aero.
The revs the box will tollerate as a function of axle ratio, wheel diameter and engine rpm.
Can you provide some more details?
Build Blog
Build Photo Album
jacko
posted on 20/2/10 at 08:35 PM |
skyline
skyline gearbox
[Edited on 20/2/10 by jacko]
bj928
posted on 20/2/10 at 10:41 PM |
BMW 5 or 6 speed, jaguar manual, T56 if you can stretch to it out of a viper/mustang/camaro/transam,
prawnabie
posted on 20/2/10 at 11:01 PM |
Id have though any box will do 200mph with the right diff/final drive?
chris mason
posted on 20/2/10 at 11:37 PM |
it's not which gearbox will cope with 200mph, it should be which gearbox can cope the bhp/torque required to get a car to 200mph.
In which case depending on the cars aero etc, you may need a gearbox that can handle 600bhp or thereabouts.
You'll also need a clutch that can handle that too.
liam.mccaffrey
posted on 20/2/10 at 11:56 PM |
as chris and i said
Also diff ratio will need to be such that the transmission itself isn't over revving
Build Blog
Build Photo Album
bj928
posted on 21/2/10 at 12:10 AM |
mine is all good for 200mph, i'm geared for 221mph in 5th, with 6th as a spare, i'm running a 2.73 diff ratio, and 550+hp, and 600+ib/ft,
then 200shot of nitous when needed.
bimbleuk
posted on 21/2/10 at 06:20 AM |
Yep the Tremec T56 (orginally designed by Borg Warner) pictured below is a good choice but you might struggle to find a cheap one. So the Skyline,
Supra, 200sx boxes will be more likely.
Image deleted by owner
Ninehigh
posted on 21/2/10 at 05:50 PM |
What engine are you using to get to 200mph?
