posted on 21/2/10 at 12:52 PM |
header tank frame - fishing for ideas
I need to mkae some sort of frame to hold by header tank, volvo 440
and looking for inspiration so post your pictures.
not sure if I sould make it from steel or aluminuim or rivet or weld it.
the base of the tank has a plastic block with sloping sides - imagin the pyramids but with the top 96 % cut off.
I am thinking of making a claw type of arragemebnt to engage in the tank and a bolting arrangement to clamp it in place - probs make no sense at all
The bracket will be bolted to a flat surface - I suppose I could bolt it to the vertial side of the scuttle but not too sure about that yet.
So ideas and photos please.
r1_pete
posted on 21/2/10 at 12:56 PM |
I built a welded steel frame, and 'glued' the tank on with silicone sealant. Worked fine on the MGB and I've just done it again with
the same tank on the Jaguar.
Will post some pics when I get home.
posted on 21/2/10 at 03:06 PM |
Might be easier and neater to get another tank --- Rover 25 tank is popular, very easy to mount.
see ebay item 110492556949
If you want a bigger tank Rover 45 tank is also a good choice
HAL 1
posted on 21/2/10 at 04:43 PM |
use the same header for my haldane, i cut a hole in a square of stainless which was about three inches larger than the tank, hole was just about big
enough to squeeze the base in then fit that to the bulkhead horizontal.
a hole was needed in the fibreglass underneath of course
does any of that make sense ?
Andybarbet
posted on 21/2/10 at 09:24 PM |
Got mine from a rover 200, good size and shape tank, made a simple ali bracket up because the one from the rover was huge ! Should fit a treat on the
scuttle, hopefully
Andybarbet
posted on 21/2/10 at 09:25 PM |
Here it is fitted to the expansion tank
Andybarbet
posted on 21/2/10 at 09:26 PM |
and another, on a different note, anyone know how to get rid of the yellowing on the bottle ?? its been in the dishwasher its very clean but still
quite yellow,
[Edited on 21/2/10 by Andybarbet]
posted on 22/2/10 at 07:54 AM |
quote: Originally posted by Andybarbet
anyone know how to get rid of the yellowing on the bottle ?? its been in the dishwasher its very clean but still quite yellow,
I cleaned mine out - aquatic gravel, washing powder and shaking followed by leaving it overnight filled with neat bleach. Cleaner but plastic is
still yellowish so the answer does appear to be no.
A new one would cure that; anyways it is just cosmetic.
