norfolkluego
posted on 27/2/10 at 10:17 PM |
Starter motor
Just goes click, I've told it to buck it's ideas up or else but to no avail. It did turn the engine once after I'd done a bit of
counselling with a hammer but it's sulking again now, any ideas
whitestu
posted on 27/2/10 at 10:23 PM |
A bigger hammer?
dave-69isit
posted on 27/2/10 at 10:41 PM |
sticking solonioid or bendix clean n lube up
Ben_Copeland
posted on 28/2/10 at 07:48 AM |
Battery dead??
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
posted on 28/2/10 at 10:54 AM |
Divorce and a younger model?
norfolkluego
posted on 28/2/10 at 07:34 PM |
Guys, could you just check my wiring, we've had no success with this today
I - Jumbo live feed direct from battery
II - switched live from ignition switch
III - earth
Can't get anything consistent to happen, probably doesn't help that we've schnozzled the battery b*ggering about all day
prawnabie
posted on 28/2/10 at 08:08 PM |
You have the connections wrong. No earth needed.
You should have 1 main wire from battery and 1 from ign switch. The Wire bolted to the same terminal as the braided wired should go in place of the
earth.
HTH
Shaun
