Lars
posted on 29/4/04 at 11:57 AM |
choke on a xflow
I read in some of the past posts that some of the racers remove the choke from their carbs on 1.3 xlow, can I do the same for my road going 1.6 xflow,
or would I have trouble starting the engine?
skinny
posted on 29/4/04 at 12:06 PM |
my dad had a twin cam alfa engine in his, twin carbs, no choke. started okish but it really needed 5 minutes just sitting there to keep alive every
time he wanted to drive it.
if you don't fail, you aren't trying hard enough.
Kitlooney1000
posted on 29/4/04 at 06:17 PM |
if you are using twin webber with an over rich mixture then the engine will start after a couple of times. I am using a standard 1.6xflow with the
original carb with no choke cable, dont have a problem starting, usually takes 2 or 3 attempts but it does start.
Lars
posted on 29/4/04 at 06:34 PM |
i have also got a standard 1.6xflow with the original carb, so will prob try without choke as well then.
what have others done?
Mark Allanson
posted on 29/4/04 at 07:02 PM |
The 60's Alfa's without chokes had hand throttles to keep the engine running once you had started it, you backed it off after a mile or
two just like a choke
phil m
posted on 3/5/04 at 08:15 PM |
I had the same issue , so I converted the water choke to a manual one. It does seem to need the choke for ease of starting, especially if it
hasn't been run for a while --like in the winter 1
i bought a cconversion kit for about 20 quid. Can't remember from who, but found it via an add. in one of the kit cat mags
Phil
posted on 3/5/04 at 08:24 PM |
I took the choke off my pinto weber carb. Pump it twice then start it and blip it till it ticks over. It soon warms up enough to run smoothly. The
racers used to remove the butterfly from the second choke on some carbs for extra power I remember from somewhere.
[Edited on 3/5/04 by Peteff]
Lars
posted on 3/5/04 at 09:56 PM |
will probably try without first, but may add a choke if i have difficulties.
does any one know if chokes manual/automatic are universal fits between carbs?
just wondering cause i have two spare carbs with one of each.
