Author: Subject: Type 9 woes
lotusmadandy
posted on 7/3/10 at 07:49 PM Reply With Quote
Type 9 woes
Hi all,
I took the indy out for the second blat of the year this morning and am having a problem with my gearbox.
while driving normaly it changes gear nice and smooth but as soon as i get a bit spirited,it refuses to engage second and crunches the synchromesh.
I have a nasty feeling that the syncro is getting weak.
What hack's me off is that i had two spare box's and i gave one away and sold the other.I know i won't be able to buy one now for the money i sold it for
All feedback and opinion's will be greatly recieved,as always.
flak monkey
posted on 7/3/10 at 07:54 PM Reply With Quote
Synchro on second is a common weak spot in a lot of boxes, and the T9 is no different.
Its not a difficult job to rebuild a box, even easier to rebuild the main shaft with new synchros as it doesnt require a full strip down.
On the other hand you can often still get them for pretty cheap prices...
Sera
http://www.motosera.com
AdrianH
posted on 7/3/10 at 07:55 PM Reply With Quote
Just a total guess, but what about when you are giving it some welly, The gearbox at the shaft end moves down. Would it be possible that the gear stick is catching on the tunnel and not going into gear properly. If so could be the gearbox mount getting soft, allowing to much travel.
Adrian
Why do I have to make the tools to finish the job? More time then money.
lotusmadandy
posted on 7/3/10 at 08:01 PM Reply With Quote
Adrian,
I have 2" clearance between the stick and the chassis member,so no problems there.
Cheers david
It looks like it could be an engine and box out job then,sh**e!!! I have just converted to zetec and finished putting the ba****d in
flak monkey
posted on 7/3/10 at 08:06 PM Reply With Quote
Could be worth trying some different oil too. Make sure its GL4 and NOT GL5, 5 isnt compatable with boxes with bronze parts like the Type 9.
Castrol do several differnt GL4 gearbox oils.
Sera
lotusmadandy
posted on 7/3/10 at 08:16 PM Reply With Quote
Thing is David,
the problem wasn't there last year with the pinto on the front of the box.The oil is the same as it has been for the last 1500 miles.
Maybe the problem has always been there but it needed a bit more power through it to bring the weak synchro to light.
Thank you for the advice,as always.
The hunt for a new box on ebay will now commence.
DRC INDY 7
posted on 7/3/10 at 08:43 PM Reply With Quote
What power is the zetec putting out over the pinto
Puddle Dodgers Club
woolly
posted on 7/3/10 at 08:47 PM Reply With Quote
as a different engine and also clutch are you sure the clutch is clearing properly when in spirit mode.
woolly
lotusmadandy
posted on 7/3/10 at 08:50 PM Reply With Quote
Tbh, i dont know.
The zetec has maybe 25-30 bhp more than the pinto but as i say maybe it just needed that bit extra to tip the balance.
Wooly,
that's what i thought but i have adjusted the clutch to give more release and it's no different.
[Edited on 7/3/10 by lotusmadandy]
Strontium Dog
posted on 7/3/10 at 09:05 PM Reply With Quote
It's not likely to be anything to do with more power (although higher revs won't help). After all your foot isn't on the gas when changing gear is it? Thick oil causing the synchro to accelerate to slowly or just plain worn out is the likely culprit IMHO. Second gear gets a caning on the change and tends to fail earliest.
kj
posted on 8/3/10 at 09:02 AM Reply With Quote
Andy u2u sent re-gear box.
By the way the car looks good on the road.
[Edited on 8/3/10 by kj]
Think about it, think about it again and then do it.
posted on 8/3/10 at 12:23 PM Reply With Quote
Possibly a silly question - but is your clutch releasing fully when you put your foot down?
Slight dragging can mess up the gearchange, and as you've just swapped engines maybe something's not quite right.
On the other hand - if it's OK - just ignore me!
lotusmadandy
posted on 8/3/10 at 07:21 PM Reply With Quote
I agree with second getting the most hammer in a seven,i think it's just knackered.
David,
the clutch does seem to be fully releasing as it will go into all other gears no problem.
Kieth,
cheers for the link mate and thanks for the comment about my car,just a shame you didn't stop when we saw each other.
mangogrooveworkshop
posted on 9/3/10 at 09:14 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=131602
