magic55
| posted on 1/5/04 at 11:40 PM |
electronic distributor
hi
if i buy an electronic distributor from a 1600cc+ xflow, will it work on my 1300gt crossflow? or will the settings and stuff be wrong?
Bob da builder
| posted on 4/5/04 at 01:55 PM |
if you use a dizzy of a MK2 fieasta i think.. about an e reg with a fiat strada 90deg cap will be cheaper and will work (thats what i have done!) the
main problem is if you fit twin webers that you need the steep intle manifold to det the dizzy under! if using the standard carb should be fine and
wont need the 90deg cap!
hope this is of use
bob
