johnH20
| posted on 11/3/10 at 08:14 PM |
Al inlet manifold blast cleaning
Hi, not sure where to post this. I am building a cut and shut ali inlet manifold from two parts , one new one used. I want to achieve a unified
appearance. What is the best process and sequence - sand, bead, other(?) blasting before or after welding. Any suggestions welcome.
blakep82
| posted on 11/3/10 at 08:18 PM |
bead/sand/media blasting won't really remove the weld showing. it will remove the metal off the weld and the parts of the manifold, just giving
a really clean weld.
edit sorry, i get you know, blast before the weld to give a good clean finish to weld together. if you want it so it doesn't look like its been
welded, then it'll be trick to get the welds sanded down though
[Edited on 11/3/10 by blakep82]
________________________
steve m
| posted on 11/3/10 at 08:27 PM |
stick it in the dishwasher
steve
johnH20
| posted on 11/3/10 at 08:59 PM |
Thanks, I am really looking to get rid of the oxidation on the old part, not disguise the weld. I have an ace welder and that will look beautiful!
austin man
| posted on 11/3/10 at 09:47 PM |
stainless steel brush then weld
| posted on 12/3/10 at 08:32 AM |
Leave it in a solution of boiled up Rhubarb leaves ( Oxalic Acid)
NS Dev
| posted on 12/3/10 at 09:18 AM |
Glass bead blast, no real comparison other than aqua blasting which is the same but wet!
Here's a Rover v8 injection inlet that had been bead blasted (by me), unfortunately have no "before" shots but it was crusty!
[Edited on 12/3/10 by NS Dev]
Angel Acevedo
| posted on 14/3/10 at 03:23 AM |
Do a search for Soda Blaster....
