rich201283
| posted on 19/3/10 at 08:21 AM |
Zetec lrs707 starter fouls sump?
My sump is a chopped and shortned mondeo sump, the rib on the side of the sump will not allow the starter to go in, my brother who also had the same
issue shaved sum off the sump but ended up haveing to get it welded as the metal went through. has anybody else had this issue?
is it possible to use the zetec starter with some plate so it bolts up with 2 bolts as it is smaller?
SeaBass
| posted on 19/3/10 at 08:37 AM |
Not sure if this is a silvertop you're referring to - I've fitted two blacktops in RWD configuration. The sump side ribs will need
grinding to fit the starter. I carefully ground mine down - it's the ribs only not the actual sump material. I've had no problems...
stuart_g
| posted on 19/3/10 at 08:38 AM |
This is normal. When the sump is fitted to the engine it is possible to move it to one side slightly, this way you don't need to grind too much
off it.
rich201283
| posted on 19/3/10 at 08:54 AM |
Hi
Yes its a silvertop, Has anyone got any pic of where try grinded?
r1_pete
| posted on 19/3/10 at 08:56 AM |
This is how I did my silvertop sump, its on a blacktop, but things are in the same place:
macc man
| posted on 19/3/10 at 10:00 AM |
hi, I had the same problem, simply grind web on sump until fits. Some starters are slightly different in size .I used one from cvh 1.8 sierra. Hope
this helps.
dunk3
| posted on 19/3/10 at 11:33 AM |
This is how much i chopped of my blacktop.
dunk3
2nd pic.jpg)
austin man
| posted on 19/3/10 at 07:41 PM |
cut a section out of my sump and had a plate welded inside to create a recess
spegru
| posted on 23/3/10 at 12:07 AM |
Hi Dunk3. I'm just doing a change from a 1.8 silvertop to a 2.0 black top. The alloy sump on the silvertop was no problem at all but the
blacktop one looks like it's going to need alot taken off to clear the starter. Did you have this problem, or maybe you have a smaller starter
(which one)?
I could use the sivertop sump i suppose but I like the two piece blacktop one as it's easy to get a shallow bottom pan. It was a long time ago
but I think my starter was from a 1.8 CVH sierra
dunk3
| posted on 23/3/10 at 08:54 AM |
Hi, i used the same starter 1.8 CVH sierra, i ground the side of the sump of with a grinder, took about an hour to do, i had the engine on a engine
stand which made it easy to get to.
| posted on 23/3/10 at 09:06 AM |
I have a DOHC starter and no mods required for the silvertop sump, fitted without any probs.
As above had to grind off the ribs on the blacktop but not too much.
spegru
| posted on 23/3/10 at 04:17 PM |
Thanks for those.
Dunk3 could you show a pic of what you did for the starter there or confirm if your pic shows the finished sump?
Coozer, could you confirm if your black top is 2.0 or 1.8 and which flywheel/bellhousing?
By the looks of it you haven't had to grind at the alloy to steel sump joint point at all. The problem point I have is there, almost directly
below the alloy X shaped webbing in the middle of your pic.
I do notice you have a weld in your steel pan though - what's that about?
Could you do a pic of your DOHC starter?
[Edited on 23/3/10 by spegru]
spegru
| posted on 23/3/10 at 06:15 PM |
I found these first two pics of a Sierra twincam (4*4) starter on ebay.
The second Three pics are of my starter that does not fit and of what I did to my sump so far.
I notices that the partnumber between thew 1.8CVH and the twincam are both G4X2A but the type is different - mine is M79(0.9) but the other is
M78R(1.4). There also appear to be some other visible differences such as where the wire comes out of the main body. What is yours like?
spegru
| posted on 23/3/10 at 06:16 PM |
ebay sierra twincam 4*4 label
spegru
| posted on 23/3/10 at 06:58 PM |
This is my CVH starter that appears not to fit
spegru
| posted on 23/3/10 at 07:00 PM |
This is the label of my CVH starter that appears not to fit.
Note that its type number is different to the Sierra twicncam 4*4 one from ebay, even though its main number is the same
spegru
| posted on 23/3/10 at 07:01 PM |
This is what I did to my sump so far. I dint grind any of the sump alloy to steel join so far but it definitely need something done!
lotusmadandy
| posted on 23/3/10 at 08:14 PM |
The twincam 4x4 starter in your first 2 pic's from ebay is mine.
Beware,it is different from a 2 wheel drive starter.
This fits fine on my 2.0 silvertop with 1.8 flywheel,though does not turn the engine.
The throw is to short to engage the ring gear.
spegru
| posted on 30/3/10 at 09:20 PM |
Found a new smaller starter as equivalent to LRS707
Found is here http://www.woodauto.com/Component.aspx?Ref=STR50041
Very Skinny and it fits without sump mods
You can see from the CVH starter next to it!
Word of warning - not tested yet but the gears are definitely the same size/ throw looks the same etc so it should be good
me!
| posted on 15/3/12 at 07:16 PM |
I know this is an old thread... his googleness brought me here! Just wondering, how did you get on with that wood auto starter spegru? And has anyone
else tried it?
I quite like the idea of not having to hack at the sump!
Bizarro
| posted on 15/3/12 at 07:43 PM |
else tried it?
I ordered one from Woodauto about 6 months back and when it came it was exactly the same size as the standard Sierra unit, so I pressume it depends
what make of starter they have in at the time.
I rang them after I received it to see if they were able to check their stock and locate a smaller bodied one but they were less than helpful and I
ended up returning it to them for a refund.
Chop the sump, its not that bad once you get started!!
me!
| posted on 15/3/12 at 09:14 PM |
Fair enough- thanks for the reply. I'll fire up the angry grinder!
