psylsph
posted on 4/5/04 at 11:29 AM |
Removing X-Flow Sump
I've manged to spring a leek in my 1300 X-Flow, is it possible to remove the sump WITHOUT taking apart the engine and gear box. I can't be
doing with the hastle of an engine removal with the nice summer weather.
posted on 4/5/04 at 11:54 AM |
In a word - no!
From painful experience (I had to remove my sump 3 times while on the car ) there are 2 bolts hidden by the bellhousing that are impossible to
remove without separating the engine and gearbox.
You could do what I did - put the front wheels on ramps, hoist the engine up a bit, unbolt the bellhousing, pull the engine forward as far as possible
(supporting the gearbox on a jack). This will give you JUST enough room to do the job. But be warned - if you fumble the 2 bolts when trying to put
them back, you'll have a very difficult job recovering them!
This is risky - if your engine hoist fails you're underneath, there's a great risk of getting something in your eyes, and if you're
not careful you can strain the clutch bits.
Oh, and it's really hard on your back as well!
DISCLAIMER: I did this, but if you try it you do it at your own risk - it's your life and you must take your own full responsibility for it.
posted on 4/5/04 at 12:24 PM |
Depends on the pattern of sump and the type of sandwhich plate usually on kent engines with an Escort box the sandwhich plate is in 2 peices the you
can get at the end 2 bolts at the flywheel end --- I think I used to use a tool made out an old allen key and a 3/8" drive socket. Worst
comes to worst just slacken the bellhousing bolts and seperate the engine box by an inch or so.
Then the sump needs a couple of thumps with a rubber mallet.
posted on 4/5/04 at 12:46 PM |
My sandwich plate was one-piece - which added considerably to my difficulty.
That plate is getting cut in two next time the engine comes out!
posted on 4/5/04 at 05:23 PM |
Is it not possible to drain the oil and repair the sump without taking it off?? even if it is only a temporary repair . ps where are you if you are
having nice summer weather ? certainly not cambridge , although it does seem to be clearing. Rusty
psylsph
posted on 5/5/04 at 11:13 AM |
Already tried repairing several times. Getting that tell tale oil dribble. I guess it's another patch and then full seperation over the winter.
posted on 5/5/04 at 12:18 PM |
Have you tried brazing or silver soldering rather than welding the joint ?
psylsph
posted on 6/5/04 at 11:40 AM |
Tried brazing etc, no joy definate needs a good clean some welding and a new hole.
jollygreengiant
posted on 8/5/04 at 10:09 PM |
Go for a new sump, their quite cheep & the only major issue is getting to the bolts at the back.
Enjoy.
psylsph
posted on 9/5/04 at 07:39 AM |
Tried before and couldn't find one. Any ideas, no scrappies in Surrey that I can find anyway.
Stuart
jollygreengiant
posted on 9/5/04 at 08:00 PM |
Tried asking engine reconditioners?
Enjoy.
