boggle
| posted on 30/3/10 at 09:10 PM |
trigger wheel....part 2...
so i cut two two trigger wheels...
not sure what one to use...
both 6mm mild steel.....
thanks mr lardarse for the drawings...
u2u me for details
blakep82
| posted on 30/3/10 at 09:11 PM |
er, what ignition system?
i'd go with the one on the right myself
________________________
Daddylonglegs
| posted on 30/3/10 at 09:12 PM |
Not much of an expert Barry, but I reckon the one on the right loks a little more substantial. Not sure what flexing can occur in the other one?
Either way, good job
JB
boggle
| posted on 30/3/10 at 09:15 PM |
blake.....its a megajolt....
john...i like my traction engine one
u2u me for details
cd.thomson
| posted on 30/3/10 at 09:16 PM |
those trigger wheels wont work with MJ
http://trigger-wheels.com/store/index1.html
[Edited on 30/3/10 by cd.thomson]
Craig
blakep82
| posted on 30/3/10 at 09:17 PM |
for mega jolt it should be 36 teeth (with 1 missing) if its with ford edis
think it needs a few more teeth
a bit like this
[Edited on 30/3/10 by blakep82]
Daddylonglegs
| posted on 30/3/10 at 09:22 PM |
See where you're coming from
boggle
| posted on 30/3/10 at 09:23 PM |
bollocks....
anyone got a drawing or sizes of what i do need???
u2u me for details
cd.thomson
| posted on 30/3/10 at 09:24 PM |
pictures on the link I posted boggle
Craig
blakep82
| posted on 30/3/10 at 09:25 PM |
hmm, not really, but basically needs to be equally size teeth and gaps. 36 of them (so a tooth every 10 degrees) and 1 of the teeth is missing (so you
actaully end up with 35 on the wheel)
boggle
| posted on 30/3/10 at 09:28 PM |
need the tooth sizes, land, root diameter and overall diamter.....
can anyone help with these???
u2u me for details
blakep82
| posted on 30/3/10 at 09:35 PM |
you won't be able to put this in the machine, but
the size of the teeth will depend on the diameter of the wheel. that picture is the one i used to have mine made, and mine works. just copy that and
scale it up or down to what you need
boggle
| posted on 30/3/10 at 09:41 PM |
so diameter is unimportant?? just the amount of teeth?
u2u me for details
blakep82
| posted on 30/3/10 at 09:43 PM |
basically yeah. the risk is, if you go too small, the teeth may not give a strong signal, but if you do it the same size as your crank pulley for
example, it should work just fine
i say the same size, but i made the teeth stick beyond the edge of the pulley to make sure the sensor didn't pick up on the pulley itself
boggle
| posted on 30/3/10 at 09:47 PM |
ok...thats what i shall do...cheers blake....
maybe a smiley face on this one???
u2u me for details
mcerd1
| posted on 30/3/10 at 09:48 PM |
I've got a cad drawing somewhere that should do it - have you got an e-mail ? (u2u it to me if you don't want it public)
[Edited on 30/3/10 by mcerd1]
boggle
| posted on 30/3/10 at 09:50 PM |
you have u2u..
thank you
u2u me for details
blakep82
| posted on 30/3/10 at 09:51 PM |
if you can get a diameter where 1 tooth completely coveres the head of the sensor, then perfect, but still make sure the teeth are the same width of
the gaps
mcerd1
| posted on 30/3/10 at 09:53 PM |
my drawing is just based on equal sizes of spaces / teeth, the one tooth removed
boggle
| posted on 30/3/10 at 09:56 PM |
that will be fine....anything to help....
u2u me for details
mcerd1
| posted on 30/3/10 at 10:00 PM |
you should have it now.........
tomprescott
| posted on 30/3/10 at 10:57 PM |
It's a shame that you can't use either of them, I personally prefer the look of the left wheel, would have thought that at 6mm it would be
substantial enough. Hope you get it sorted.
A bird in the hand....
andyw7de
| posted on 31/3/10 at 08:08 AM |
Drawing sent Barry
mcerd1
| posted on 31/3/10 at 08:47 AM |
I've also done a simplified 2D *.dxf (attached if anyone wants it)
its 5.125" dia. (~130mm) and has a 12mm hole in the middle
