Author: Subject: have i got this right?
blakep82
posted on 4/4/10 at 01:29 AM Reply With Quote
does this look right?
white box is the engine, dark blue is header tank with pressure cap, grey box is radiator, green box is fan, blue pipe is the lower hose, red one is the top hose. grey bits in the pipes are alu hose joiners. wiggly green lines are wires for fan switch and temp gauge. black lines are the overflow air bleed hoses.
so, does it look right?
going to order silicone hoses, the bottom hose i'm going to try the flexi wire reinforced stuff, its smooth bore inside, but they only do 30mm, 32mm, and 35mm, the connections on my engine are 34mm, so do i go 35mm as the bead is bigger than that, or go 32mm, not really knowing if the wire reinforcment will stretch.
is there anything i've missed in the diagram?
________________________
dogwood
posted on 4/4/10 at 07:10 AM Reply With Quote
Looks about right to me..
Here's my dodgy comp diagram..
FREE THE ROADSTER ONE…!!
speedystew
posted on 4/4/10 at 10:29 AM Reply With Quote
is the engine a vauxhall xe by any chance ? if so you have it all ok apart from the breather in the top hose (thermostat area) is not needed the air bleed on the radiator sorts that part out
also you need to blank the head at the rear if not running a heater
blakep82
posted on 4/4/10 at 10:49 AM Reply With Quote
good man, i was hoping you'd say that some people say the head cooling is affected without the heater, but i've blanked it off just made up a ali plate the same shape as the gasket and bolted it on.
as for the thermostat bleed thing, its easier to run it to the header really rather than blank it off. i did however blank off the one above the alternator (the other end of the heater pipe)
and good guess on the engine, but its a XEV ecotec. kinda the same but different
dogwood, thats cool, pretty much the same as my plan, only you've got the manifold connected in, but you got the same air bled in the radiator and thermostat, good times
