Author: Subject: valve grinding
beaver34
posted on 12/4/10 at 06:15 PM Reply With Quote
valve grinding
is there an easier way or better tool than a stupid stick with crap rubber thing on end!
clairetoo
posted on 12/4/10 at 06:18 PM Reply With Quote
In a word.................no
Its cuz I is blond , innit
Claire xx
Will weld for food......
beaver34
posted on 12/4/10 at 06:22 PM Reply With Quote
boo!
i hate this job swore i would never do it again last time, things you do for more power
Stuart_B
posted on 12/4/10 at 06:24 PM Reply With Quote
as said these is not much out there apart from the stick.
it just takes time if you are lucky are are doing a 8v and not any more.fun with the duratec rebuild.
stuart
A1
posted on 12/4/10 at 06:26 PM Reply With Quote
i found that if you lift it off the seat before changing direction it stops it coming off. also making sure its in a straight line with the valve helps too. obvious i know, but it makes a really effing annoying job bareable
will121
posted on 12/4/10 at 06:28 PM Reply With Quote
just done 16 valves with a stick, i did considder one of these eezilap tools to do in a drill but not sure what they are like.
beaver34
posted on 12/4/10 at 06:32 PM Reply With Quote
stuart
nah 16v zetec se
MakeEverything
posted on 12/4/10 at 06:39 PM Reply With Quote
imagine a 24V V6!
Kindest Regards,
Richard.
beaver34
posted on 12/4/10 at 06:40 PM Reply With Quote
Originally posted by MakeEverything
imagine a 24V V6!
thats why i went for a girls engine
posted on 12/4/10 at 06:53 PM Reply With Quote
SPQR used to make Oscillating Valve Lapper tool for the end of a slow speed electric drill --- I still have mine it works great.
These days Gunson make the Eezilap Gunson model number G4095. Only difference I can see it is made of black plastic instead of oranged
see http://www.toolsheduk.com/Q/1148/2/28/Eezilap-Valve-Lapper.html Rescued attachment g4095.jpg
adithorp
posted on 12/4/10 at 07:28 PM Reply With Quote
Two tips for grinding...
1, Get a tune in your head and grind to that tune.
2, Adding a drop of paraffin to the paste makes it a lot easier on the hands... and improves the grind.
adrian
http://jpsc.org.uk/forum/
richard
posted on 12/4/10 at 07:52 PM Reply With Quote
Am i the only one who as attached a electric drill to the top end of a valve and on slow speed pulled it towards me rather than used the stick method.
Ive done this on 2.8 3 litre and pinto engines so not sure if works on all engines.
Rich
pewe
posted on 12/4/10 at 07:58 PM Reply With Quote
Put a thinish coil spring under the valve head up into the port - stands the valve off the face until you put pressure onto the grinding tool.
As above ^^ a drop of paraffin helps you hear the grinding paste doing its job.
PIA job but worth it when you see that nice dull grey ring.
Cheers, Pewe
Daddylonglegs
posted on 12/4/10 at 08:11 PM Reply With Quote
Originally posted by richard
Am i the only one who as attached a electric drill to the top end of a valve and on slow speed pulled it towards me rather than used the stick method?
Nope! I've done that several times too Rich
As long as you're careful and don't try to rush, keep the drill on a low speed and don't apply too much pressure it works a treat
clairetoo
posted on 12/4/10 at 09:13 PM Reply With Quote
imagine a 24V V6!
That'd be a 24 valve v6 then
Claire xx
beaver34
posted on 12/4/10 at 09:22 PM Reply With Quote
imagine a 24V V6!
posted on 13/4/10 at 05:58 PM Reply With Quote
Tried to teach an apprentice how to lap valves in a couple of years ago, he soon lost interest. Once you have mastered the technique it's easy.
Ivan
posted on 14/4/10 at 06:13 AM Reply With Quote
Used to have a grinder that was like a hand drill with suction cup on end some sort of mechanism that swapped direction every few revs - don't know what happened to it but I am sure a hand drill would work just as well, just reverse the direction every ten seconds or so.
iti_uk
Builder
Posts 163
Registered 13/10/08
Member Is Offline
Photo Archive Go!
Building: The KLMX-5 ('97 MX5 w/Mazda KL 2.5L V6)
posted on 14/4/10 at 02:12 PM Reply With Quote
imagine a 24V V6!
Ahem...
Just because it's in an MX5...
Chris
posted on 14/4/10 at 05:52 PM Reply With Quote
Rich
Really not the way to do it ---- seriously a great way end up with scored the valve seats all it needs is one oversize particle in the grinding paste.
Valve should never be allowed to rotate more than about 180 degrees before reversing the direction of rotation. After between 10 and 15 cycles the valve should be lifted off its seat and turned through between 60 and 120 degrees to a new starting position and the lapping procedure re-commenced.
Mechanical fitters have been lapping in valves since the first steam engines were built, best practice methods were established through experience.
