Author: Subject: Xflow
leon51274
posted on 16/4/10 at 04:18 PM Reply With Quote
Xflow
A couple of things for you experts to help me with.
Just fitted a set of dellorto dhla 40's and had my bosch dissy modified by h&h. I've had the engine running a couple of times and it runs sweet, however trying to get it started is a first class pig, almost getting to the extent of running the battery flat but like i say when running it runs fine, timing has been set at 14deg so i'm pretty sure i'm ok in that department.
The other thing, is while it isn't running i've got a fuel leak under one of the carbs where the throttle lingage enters the carb which if you pull on the lever is fair p---ing out! If the engine is running there's no leak! Could this just be seal?
And advice is welcomed
Leon
norfolkluego
posted on 16/4/10 at 06:15 PM Reply With Quote
Do you use the choke to start, my Crossflow had twin DHLAs and would never start without holding the choke open.
posted on 16/4/10 at 06:38 PM Reply With Quote
what lever - you mean the one that pushes on the enrichment valve at the underside of the carbs?
sounds like the diaphragm has gone.
there is an art to starting a corssflow, as follows.
press the accelerator pedal fully down thre or 4 times - this pumps fuel via the enrichment device.
hold choke open - now this can be full/1/2 or a tiny amount depending on engine and air temp - you need to find out what this is for your engine.,
trun the engine over, push the accelerator down
bingo.
note that you may hear the engine cathcing - so push in or pull out the throttle - eventually you work out how much choke you need.
you must sort out that leak - or else ensure your insurance covers you for fire.
try static timing at 10 degrees,
[Edited on 16/4/10 by 02GF74]
posted on 16/4/10 at 08:51 PM Reply With Quote
The "four pumps then crank" technique is fine if you've got a standard carb with an accelerator pump (e.g. the Weber 32/36 I used to have) but it wouldn't help with my current set of bike carbs!
If the DHLA carbs have an accelerator pump then the technique may be OK, but if not then you're wasting time and effort. Proper use of the choke is the best policy - and that depends on the carbs too!
norfolkluego
posted on 16/4/10 at 10:04 PM Reply With Quote
Pumping the accelerator never worked with my Crossflow/DHLA (did with my Tiger Pinto with DCOEs), always had to use the choke.
posted on 17/4/10 at 12:40 PM Reply With Quote
yes they do - I speak from experience
some DHLA's yesterday. (accelerator pump and lever is in the middle of both carbs)
leon51274
posted on 19/4/10 at 08:28 AM Reply With Quote
Thats where my fuel is leaking from! Its coming out from where the lever is. So is this the diaphram?
