Author: Subject: Symbols on warning lights?
NS Dev
posted on 14/5/04 at 07:51 AM Reply With Quote
On warning lights such as the brake fluid warning light, does the appropriate symbol have to be actually on the lamp or can it be immediately above it on the dash? (so it is obvious which lamp is refers to)
I have some lovely flush mount black anodised alloy surround LED's for warning lamps and don't really wish to put stickers on them, especially as a friend will engrave my dash around the LED's and can engrave the symbols directly into the alloy dash before it is anodised!!
jonti
posted on 14/5/04 at 08:23 AM Reply With Quote
I would have thought (although someone may know otherwise) that, as long as its clear what the lamp is indicating, then you should be ok.
OFROK
posted on 14/5/04 at 08:35 AM Reply With Quote
i was wondering this too, someone failed recently on this one. i got 6 leds with no marks on the bulbs, all fitted to the dash so i dont want to change them.
richijenkin
posted on 14/5/04 at 08:45 AM Reply With Quote
Thought you had to be able to see what they are in the dark?
[Edited on 14/5/04 by richijenkin]
colibriman
posted on 14/5/04 at 08:55 AM Reply With Quote
can i add another question about warning lights....?
is there any specific position they need to be in...?
cheers
colin
[Edited on 14/5/04 by colibriman]
spunky
posted on 14/5/04 at 09:04 AM Reply With Quote
No specific position, but must be visable from the normal driving position, IIRC.
John
posted on 14/5/04 at 09:37 AM Reply With Quote
I've only seen mention of the brake fluid/handbrake warning needing a symbol on the actual light. The others are all standard colours, blue/main beam, green/indicators, red/charging and orange/oil light.
barrie sharp
posted on 14/5/04 at 10:30 AM Reply With Quote
I ve just passed and the only symbol that they were interested in was the brake warning on the lamp
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
NS Dev
posted on 15/5/04 at 10:23 AM Reply With Quote
and that had to be "on" the lamp, not next to it??
posted on 15/5/04 at 03:18 PM Reply With Quote
as long as it's illuminated:
[Edited on 15-5-04 by Hellfire]
