Author: Subject: Airbox finished
flak monkey
posted on 5/5/10 at 08:03 PM Reply With Quote
Airbox finished
Nearly finished off the carbon airbox tonight should keep cold air being pulled in even when stationary or in traffic.
Ok so its not fancy or particularly pretty, but its light and should do the job
Air box 1
Air box 1
Air box 2
Air box 2
Air box 3
Air box 3
Cold air is drawn in the vents in the side of the bonnet
[Edited on 5/5/10 by flak monkey]
Sera
http://www.motosera.com
Steve Hignett
posted on 5/5/10 at 08:06 PM Reply With Quote
Looking good mate...
U2U2U...
welderman
posted on 5/5/10 at 08:09 PM Reply With Quote
ye looks ok to me from here
Thank's, Joe
I don't stalk people
andrew-theasby
posted on 5/5/10 at 08:21 PM Reply With Quote
What does the hole/scoop in the bonnet lok like? Im planning something similar but havent decided where to pick up the cold air. Ps sorry if ive missed it in a previous post
flak monkey
posted on 5/5/10 at 08:34 PM Reply With Quote
Like this
Side close 1
Side close 1
Sera
andrew-theasby
posted on 5/5/10 at 08:43 PM Reply With Quote
Thats nice and tidy, is there a minimum size it needs to be? I was worried about my idea not being big enough!
flak monkey
posted on 5/5/10 at 08:45 PM Reply With Quote
I dont suppose there is as long as it will flow the CFM required easily....
If I get problems I will make some bigger vents
Sera
andrew-theasby
posted on 5/5/10 at 08:56 PM Reply With Quote
Good old trial and error
flak monkey
posted on 5/5/10 at 09:03 PM Reply With Quote
Yep, the slots are fairly big anyway - 20mm wide and 100, 75 and 50mm long.
Sera
posted on 5/5/10 at 09:09 PM Reply With Quote
Probably doesn't make a lot of difference, but aren't those slots in a fairly low pressure area? NACA duct might be quite effective?
[Edited on 5/5/10 by MikeRJ]
mangogrooveworkshop
posted on 5/5/10 at 10:44 PM Reply With Quote
That's a very good solution for the limited space you have under bonnet.
jeffw
posted on 6/5/10 at 05:21 AM Reply With Quote
Would a NACA duct on the top of the bonnet not give you a slight ram air effect which might improve the airflow...
goaty
posted on 6/5/10 at 07:53 AM Reply With Quote
that looks spot on david, should work a treat
atspeed racing
posted on 6/5/10 at 08:49 AM Reply With Quote
very impressive installation
- colin.
flak monkey
posted on 6/5/10 at 08:56 AM Reply With Quote
Thanks chaps
I was looking at the Naca Ducts at Stoneleigh, but didnt have enough money to get one at the time.
Maybe an addition for next winter
Sera
