Author: Subject: Fuel Pipe
MikeR
posted on 14/5/04 at 12:03 PM Reply With Quote
Fuel Pipe
Question, if we use special coper pipe for brakes, should we use special copper pipe for the fuel line?
Ebay has an auction of 8mm fuel 'ford' pipe. I was just thinknig if plain copper is ok, I could go and buy 8mm central heating pipe.
stephen_gusterson
posted on 14/5/04 at 02:17 PM Reply With Quote
many people have used std heating copper pipe. there is a school of thought that says copper reacts with fuel to produce sludge, but its been said on here that only counts for low grade fuels........
atb
steve
posted on 14/5/04 at 03:00 PM Reply With Quote
We used small bore (10mm) not microbore (8mm) as the ID of the bike pipes for our engine are 10mm.
HTH
MikeR
posted on 14/5/04 at 10:20 PM Reply With Quote
Hmmm, looks like I might be popping off to stewarts heating and plumbing supplies then
2m of 10mm, 2 olives and some solder has to be cheaper than the bloke selling 5m of the stuff inc postage for 10 pounds.
[Edited on 14/5/04 by MikeR]
Mark Allanson
posted on 14/5/04 at 10:27 PM Reply With Quote
I am a little concerned about the SVA with microbore, should the pipe have special markings indicating fuel usage?
stephen_gusterson
posted on 14/5/04 at 10:32 PM Reply With Quote
most rubber fuel pipe I have seen is 8mm internal bore.... so using 10mm pipe might make life hard.
whats the dia of the engine end it connects to? you dont wanna be connecting 10mm hose to 8mm fittings.....
atb
steve
ps - even my 'big' 2.4 V6 is fuelled by 8mm
Mark Allanson
posted on 14/5/04 at 10:34 PM Reply With Quote
Sierra uses 8mm throughout, so as soon as the marking thing is cleared up, thats what I will use
posted on 14/5/04 at 11:30 PM Reply With Quote
I used 8mm copper, no problem, and 3/16th copper for return pipe.
posted on 15/5/04 at 07:47 AM Reply With Quote
i bought 4 meters of rubber hose for around 10 to 15 squids. more than enough and easily flexible. still, whatever tickles your plums!
leto
posted on 15/5/04 at 08:02 AM Reply With Quote
Note for the safety nut:
Metal fuel pipes should be connected to (electrical) ground at some point. The flow of fuel can build static charges that cause sparks.
“I'm gonna ride around in style
I'm gonna drive everybody wild
'Cause I'll have the only one there is a round”. (J. Cash)
MikeR
posted on 15/5/04 at 11:51 AM Reply With Quote
Hmm, interesting comments. One of the reasons I wanted to go copper was cause i've got a long term plan (heck, this cars 4 years in the building already) to convert to Fuel Injection. I thought it would be easier and cheaper to plum in two fuel lines now and then add the fuel injection proof rubber when needed than shell out for all fuel injected rubber now.
Where did you get your fuel hose from for 10 to 15 pounds and was it high pressure hose?
posted on 15/5/04 at 02:07 PM Reply With Quote
Steel fuel pipe on cars isn't earthed. If something runs to earth that's what causes sparks isn't it?
MikeR
posted on 15/5/04 at 02:34 PM Reply With Quote
Just realising i'm being a complete muppet. One of my mates is an engineer for BMW and ...... works on the fuel tank / fuel supply line side of things !!!
I'll ask him and get back to you all (if he's not disappeared to china for a month)
Rob Allison
posted on 15/5/04 at 07:46 PM Reply With Quote
If anyone is after good cheep rubber fuel pipe try www.arco.co.uk lots of sizes.
posted on 15/5/04 at 08:31 PM Reply With Quote
IIRC the rubber fuel pipe has to be marked up as fuel pipe compliant or other I.D. (IIRC)
Regarding the 10mm OD pipe - our bike fuel pipes were 10mm ID that's why we used 10mm. If sierra is 8mm then it makes more sense to use 8mm.
madforfishing
posted on 16/5/04 at 08:25 AM Reply With Quote
Pete, don't get confused with earthing something that is directly connection to a live source - that will cause a spark.
For confirmation of fuel flow causing static electricity build-up have a look at an HGV fuel tanker the next time one is delivering to a petrol station. They have a thick Earth Bonding Cable which they attach before fuel is pumped.
In regard to earthing the fuel lines, I am sure that it will be unintentionally earthed along it's path to and from the tank / engine anyway.
Please come and visit me in Princess Royal Hospital's burns unit if I am wrong. (Grapes not Flowers please).
Regards,
Rick
