55ant
| posted on 12/5/10 at 02:36 PM |
Rev Limiter
Hi guys, i have no idea if i have a rev limiter, but ill assume i dont. my ignition is an h&h solutions coil and dizzy, would this have a limiter
built in?
i really have no idea what it looks like etc,
if it turns out i dont have one could someone recomend me one for a pinto please! preferably adjustable.
away from cars, now cycling and building TT bikes
cd.thomson
| posted on 12/5/10 at 02:42 PM |
just keep revving it until it stops.
if it stops with a bang then no rev limiter
if it cuts out and comes back once the revs drop then its a hard limiter.
if it the advance drops to 0 for a while before it blows then it was a soft limiter.
Craig
scudderfish
| posted on 12/5/10 at 02:51 PM |
I have an adjustable one doing nothing. It's for a V8, but if you set it to double what you want it should work.
flak monkey
| posted on 12/5/10 at 02:58 PM |
No it wont have one unless its got a limiting rotor arm.
Sera
http://www.motosera.com
omega0684
| posted on 12/5/10 at 03:04 PM |
i have an omex shift light and limiter module at home. its for coil & dizzy applications too, i was going to use it on my pinto when i was running
an aldon ignition system but never got around to fitting it.
if your interested send me a u2u
55ant
| posted on 12/5/10 at 03:29 PM |
right cheers guys, that clears it up a bit, im off to have a look what i have at the moment, back later!
Bluemoon
| posted on 12/5/10 at 04:38 PM |
My stadard ford setup (CVH) seems to (found out when the throttle jammed open!).. Don't really on the limiter to save the engine though as it
stops the ignition but the fuel is still there and this will wash the oil film from the bores etc etc... Good for occasional engine saving, in the
heat of the moment, or if the throttle jams!
Dan
daviep
| posted on 12/5/10 at 06:19 PM |
quote: Originally posted by Bluemoon
Don't really on the limiter to save the engine though as it stops the ignition but the fuel is still there and this will wash the oil film from
the bores etc etc!
Dan
Nonsense.
[Edited on 12/5/10 by daviep]
Bluemoon
| posted on 14/5/10 at 08:56 AM |
the bores etc etc!
Dan
Nonsense.
Maybe, I'd like to know why it's "nonsense".. The above is my understanding (and that's not always 100%, after all we
are all learning or I would not bother being on the forum)..
Dan
daviep
| posted on 22/5/10 at 04:47 PM |
the bores etc etc!
Dan
Nonsense.
Dan
The amount of unburnt fuel and the length of time the ignition is cut for is not enough to do significant engine damage.
Might get some backfiring.
