shaywez
posted on 16/5/04 at 09:45 PM |
Engine gearbox combination
Hope somebody can help me. What is the best way to fit a mt 75 box to a 2.0L Zetec engine? Do i need to fit a different flywheel, clutch etc. Any
help would be much appreciated
zetec
| posted on 17/5/04 at 07:28 AM |
Easy to do. I think you can use 1.8/2.0 flywheel. Not sure which clutch but should be a standard Ford part, I fitted a lightened unit from Dunnel and
they also supplied the clutch (which I suspect was straight from Ford). You will aslo need a Sierra spigot bearing which is a couple of quid. I used a
DOHC Sierra starter motor, but others fit.
shaywez
posted on 17/5/04 at 05:39 PM |
Thanks Zetec for your help
