Author: Subject: Which Starter?
mad4x4
posted on 24/5/10 at 08:42 PM Reply With Quote
Which Starter?
Which Starter do I need for a Type 9 Coupled to a Zetec 1.8.
is it the Sierria Starter or the Mondeo one
Scot's do it better in Kilts.
doddy
posted on 24/5/10 at 08:48 PM Reply With Quote
sierra dohc one part lr707 i think it is
or somepeople have used a pinto one but you have to space it out
austin man
posted on 24/5/10 at 09:53 PM Reply With Quote
dohc starter or 1.8 sierra one, I undertand that the standard one can also be used if used in conjunction with a 14mm spacer
r1_pete
posted on 25/5/10 at 07:18 AM Reply With Quote
QX Components QS1221
starter2
starter2
lotusmadandy
posted on 25/5/10 at 12:33 PM Reply With Quote
Austin man is quite correct,a pinto starter can be used with a 14mm spacer.
I know this because i am using this very set up.
