Mave
| posted on 20/5/04 at 06:51 AM |
ECU on Zetec
I just found out that my ECU is probably useless; my 2.0 Mondeo Zetec engine comes from an automatic, and according to Haynes they seem to have a
seperate ignition module "EDIS" (which I don't have).
Manuals have this ignition module integrated in the ECU, so I guess I have to find a manual ECU....right?
My budget goes through the roof!
SeaBass
| posted on 20/5/04 at 07:45 AM |
I'm just about to put a Zetec in my car. Are you trying to use the standard plenum etc?? This is a pretty difficult route I've heard as
the ECU needs lots of systems working to function correctly. I'm looking into carbs and a seperate ignition module or (ideally) throttle bodies
and management.
You can use the EDIS (Electronic Distributorless Ignition System) found on other fords running carbs which is a seperate unit.
See here for more info:
http://cyclops.dmu.ac.uk/tiger/paul/zetec-budget.html
zetec
| posted on 20/5/04 at 08:28 AM |
I fitted an Emerald unit. It really is plug and play with either carbs or throttle bodies.
dutchsuperseven
| posted on 20/5/04 at 09:22 AM |
Hang on dude,
Robbie to the rescue!!!
Sex, drugs and Supersevens
mad4x4
| posted on 20/5/04 at 10:47 AM |
we fitted a EEC -IV + zetec 1.8 engine to a Mark II fiesta
Have a look at
http://www.xr2zetec.co.uk
Scot's do it better in Kilts.
Mave
| posted on 20/5/04 at 11:38 AM |
How do I know if my ECU is the right one? It is an EEC-IV, and there are some other numbers on it.
The scrappy where I bought my engine, also sold me this ECU, and told me it was the one from this engine. Sooo, if I understand Haynes correctly, I
will have the one without EDIS!?!?!
Oh, by the way: yes, my intention is to use the complete Ford ignition/inlet/computer system.
Any help is appreciated. I'm not looking forward to buying a second ECU, as these things don't come cheap.
givemethebighammer
| posted on 21/5/04 at 01:42 PM |
AS per U2U - how to use Ford ECU with zetec.
Never tried it but this guy has and apparently it works
James
| posted on 21/5/04 at 06:49 PM |
Megaquirt!
Need I say more?!
James
