Author: Subject: Pinto auxillary shaft
chrisg
posted on 22/8/02 at 09:00 PM Reply With Quote
Hello chaps,
as you may have seen elsewhere my new engine is coming out of an EFI engined granada, which has an electric fuel pump.
I have a manual fuel pump and the pushrod, but the thought occurs......
Will the auxillary shaft have the cam on it that drives the fuel pump or will I have to swap the shaft from my other engine?
Any ideas??
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
stephen_gusterson
posted on 22/8/02 at 09:27 PM Reply With Quote
an alternative is to use an SU electric fuel pump as found on old minis and morris minors, etc. that would be way easier than a cam swap.
atb
steve
theconrodkid
posted on 22/8/02 at 10:42 PM Reply With Quote
should have the cam,be a bit silly to make 2 different shafts,one way to find out.
chrisg
posted on 23/8/02 at 05:39 PM Reply With Quote
Yeah John, I suppose. Didn't want to put the thing in the car, only to have to take it out again!
Chris
posted on 23/8/02 at 07:43 PM Reply With Quote
Check the length of the pushrod 'cos I swapped one on mine for an identical looking one from the scrapyard and it had a longer pushrod so it broke first time round. I checked the next one carefully. Don't waste another £2.
yours, Pete.
