stevem2727
posted on 6/6/10 at 02:41 PM |
Front uj knocking on chassis
Help please.I have a mk indy with a pinto and sierra gearbox.Over big bumps on the road or trying to go quickly round a corner i get the most
horrendous banging noise.I have removed the inspection flap covering the propshaft and can see markings on the chassis where the front uj is hitting
it.Has anyone else had this problem and been able to rectify it,any advise very welcome thanks.
RichardK
| posted on 6/6/10 at 02:46 PM |
Stiffer or replace worn gearbox mounts?
Got to be the first thing to do...
Rich
Gallery updated 11/01/2011
stevem2727
| posted on 6/6/10 at 02:48 PM |
Hi the car has only done 600 miles and to be honest has always done it.Any ideas on where to get stiffer mounts? thanks
| posted on 6/6/10 at 03:11 PM |
My type 9 has no gearbox mount, its bolted straight to the chassis through a 5mmish thick hard rubber pad.
turbodisplay
| posted on 6/6/10 at 03:38 PM |
Burton power do them, not cheap but really stiff in comparison.
Or use a susspension bush, and make mounts from that.
Darrren
jacko
| posted on 6/6/10 at 04:13 PM |
As above + fit a engine stabilizer
  engine mounting
[img][/img]
This is what i made to stop the engine / box moving side to side
Jacko
[Edited on 6/6/10 by jacko]
Marcus
| posted on 6/6/10 at 06:59 PM |
Mine did the same thing, so I cut out the chassis section that was contacting and welded it back in 2 inchea further back
Marcus
Because kits are for girls!!
whitestu
| posted on 6/6/10 at 07:14 PM |
Read this thread - might help.
Link
Stu
