Author: Subject: 1600 Crossflow - Exchange / refurbed Engine
crezza
posted on 23/6/10 at 02:43 PM Reply With Quote
Engine in our locost is a bit tired and smoky, can anyone recommend a good exchange / refurb provider near surrey? Or otherwise of a good secondhand unit for sale?
Ta
Stephen
07900606262
posted on 23/6/10 at 03:31 PM Reply With Quote
I'll say it before anyone else does - why spend money on such an old engine, when you can get a zetec for next to nothing? You will have to spend some money adapting stuff to make it fit, but you'll have higher power output and a much newer engine.
...and this is a dedicated x-flow owner saying this!
dave-69isit
posted on 23/6/10 at 03:35 PM Reply With Quote
valve guide smocky or rings does it only smoke when cold
atspeed racing
posted on 23/6/10 at 03:39 PM Reply With Quote
Wise words from David.
Just got to spend a few quid making it fit, but you will end up with a far better unit.
Fatgadget
posted on 23/6/10 at 04:29 PM Reply With Quote
While I agree with what you are saying about a morden Zetec,there is something very alluring in an old fashioned engine like a xflow in a Lotus 7 type car
atspeed racing
posted on 23/6/10 at 04:41 PM Reply With Quote
agree there...
an all steel x-flow at 9000rpm does sound VERY good on our dyno
posted on 23/6/10 at 05:19 PM Reply With Quote
And at least with a Xflow you know you chassis won't get a chance to go rusty with all that oil flying around the engine bay
mangogrooveworkshop
posted on 23/6/10 at 05:42 PM Reply With Quote
just a few years back you could buy them in SA new from ford for 800 rand.......
Sell the xflow to the classic ford boys...they will munch your hand off.
posted on 23/6/10 at 09:04 PM Reply With Quote
Don't get me wrong - I do like my x-flow and I'm not rushing to get rid of it. But if it should need significant money spent on it then it will get changed rather than fixed.
posted on 24/6/10 at 08:48 AM Reply With Quote
check Newark engines on ebay (trade under letterslost) or contact them (yellow pages). they have recon blocks and heads.
there is also burton power and vulcan engineering.
^^^ whilst I'd agree with the zetec route -(I have 2,m don't ask) but fitting one would mean bonnet bulge and I did not want that - even going from 1300 to 1600 block I had to make engine mounts for it to fit!
posted on 24/6/10 at 09:10 PM Reply With Quote
That's true - the Zetec is a tall engine. Not an impossible task though.
The only popular engine I've seen that's comparable in size to the x-flow is the Toyota 4-AGE - a remarkably small engine. That's quite an expensive route though as the engines aren't cheap, and finding a suitable RWD gearbox is even more expensive! Even using a Ford Type 9 box involves an expensive replacement bellhousing. That's a simple way to get 130BHP from a bog-standard 1600cc engine though. And they are quick...
