chipie
posted on 25/5/04 at 10:37 AM |
Air Filter Clearance - home made filters?
I only have a gap of approximately 15mm between the end of one of my trumpets to the chassis. I've got Webber 45s, a shortened manifold and very
small trumpets. Two trumpets have a shortened ITG sock filter fitted, but fitting the ITG to trumpet 1 means it is squashed between the chassis and
the end of the trumpet with no gap. The engine has trouble breathing and won't run properly.
I have to have a good filter as it is used in dusty areas. Does anyone have any ideas for filters or what material I can use. Any diagrams of home
made filters used in small spaces would be most appreciated.
Unfortunately angled inlet manifolds are not an option.
Glan Noye
posted on 25/5/04 at 12:26 PM |
Have you considered making an air box and having a remote filter?This is what I am doing.You could have the inlet at the front of the car drawing cold
air. Glan.
