Irony
| posted on 21/7/10 at 07:32 PM |
Rv8 Oil pump Inlet/Sensors
Here is a picture of my V8 oil pump. Can some one tell me what all the inlets/outlets sensors do? I know that C is the pressure relief valve.
mark chandler
| posted on 21/7/10 at 08:31 PM |
They made more than one type of these, that looks like a very early range rover one to me.
You get:
-low pressure switch
-Electric oil pressure sender
-Electric oil tempreture sender
From your bits it looks like D has a capillery oil pressure gauge adaptor fitted.
Regards Mark
Agriv8
| posted on 21/7/10 at 08:35 PM |
from memory
a low presure light dash
b low presure to ecu (cuts engine )
c presure relife valve ( regulates what little oil pres ure you have ) CLEAN THIS
d presure gauge ( if fitted )
( a and b ) are interchangable
Simon
| posted on 22/7/10 at 11:29 PM |
quote: Originally posted by Agriv8
from memory
Concur with this as mine stuck and I had about 2psi for a couple of miles (and knocking afterwards!)
Simon
