brookie
| posted on 26/7/10 at 07:31 PM |
what diff in my car
ok then what diff have i got in my car
sorry dont now how to put photo up there one in the photo section thank u
[Edited on 26/7/10 by brookie]
interestedparty
| posted on 26/7/10 at 07:35 PM |
dunno
| posted on 26/7/10 at 07:36 PM |
Sierra 7" diff. Ratio 3.62:1
Phil
RAYLEE29
| posted on 26/7/10 at 07:41 PM |
a piccie might help!
Ray
[Edited on 26/7/10 by RAYLEE29]
Killer
| posted on 26/7/10 at 07:42 PM |
  diff
What did it come off?
Got the vin plate off the car it came off, otherwise crack off the cove and count the teeth
Failing that just name it Trevor!
[Edited on 26/7/10 by Killer]
RAYLEE29
| posted on 26/7/10 at 07:45 PM |
ok sierra 7" diff bolt on shafts if it had a tag then that would tell you the ratio
Ray
| posted on 26/7/10 at 07:47 PM |
7" Sierra diff. To check the ratio, put a mark on the input flange or propshaft and count how many revolutions it takes to complete one full
turn of the wheel. It will almost certainly be either 3.62 or 3.92
Phil
tomgregory2000
| posted on 26/7/10 at 07:49 PM |
i name your diff steve!
RAYLEE29
| posted on 26/7/10 at 07:57 PM |
lol was gonna say edward but thought id try and help
Ray
| posted on 26/7/10 at 08:02 PM |
Is that not the 7.5"???
It's Evolution Baby!
| posted on 26/7/10 at 08:03 PM |
Where are these infamous tags? Never seen one on a diff but might be looking in the wrong places
jase380
| posted on 26/7/10 at 08:07 PM |
tags are normaly attached to one of the diff cover bolts, but in my experience are that rotten and covered in poo you cant read em anyway
brookie
there loads of numbers on it but cant make them out so what the best way of doing it them make it as simple as pos please im new to this and still
learning
Killer
| posted on 26/7/10 at 08:13 PM |
  2 diffs
interestedparty
| posted on 26/7/10 at 08:28 PM |
Do what Hellfire said and count how many times the input needs to go round to get the outputs (shafts) to do one full turn. You need to check both,
and it they end up in slightly different places, average it so one is ahead by the same amount as one is behind if you see what I mean.
mcerd1
| posted on 27/7/10 at 10:06 AM |
brookie: "sorry dont now how to put photo up there one in the photo section thank u"
copy the bit of code under the pic - and paste that into your post like this:
[pg=48498] (ive turned off the BB code in this post so you can see the code not the pic)
as for which diff - whats under those plastic caps on the top mount, is it the bolt heads or the nuts ?
[Edited on 27/7/2010 by mcerd1]
Liam
| posted on 27/7/10 at 10:33 AM |
Nope
brookie
| posted on 28/7/10 at 04:28 PM |
right now found out it the 3.62 diff
