Author: Subject: Pictures of a zetec on a stand
RichardK
posted on 26/7/10 at 10:04 PM Reply With Quote
Not sure on which holes to use, would like it on its side.
So how have you guys mounted yours?
Pictures would fantastic...
Rich
Gallery updated 11/01/2011
MakeEverything
posted on 26/7/10 at 10:06 PM Reply With Quote
You can mount it by the bellhousing bolts or the exhaust studs and engine mount holes.
Kindest Regards,
Richard.
RMarine
posted on 26/7/10 at 10:27 PM Reply With Quote
Heres mine
[img] Description
[/img]
loggyboy
posted on 26/7/10 at 10:50 PM Reply With Quote
I wouldnt use exhaust suds, could cause stress on alloy areas.
Bellhousing is best, stand should allow you mount and adjust so centre of gravity is such that the engine can be spun at any angle.
Danozeman
posted on 27/7/10 at 06:16 AM Reply With Quote
MIne was as above.
Dan
big_wasa
posted on 27/7/10 at 06:34 AM Reply With Quote
mine also as above
bonzoronnie
posted on 27/7/10 at 09:48 AM Reply With Quote
Mounted mine the same Rich
posted on 27/7/10 at 10:00 AM Reply With Quote
Zetec on a stand.... next to a broken V8
Spare head bolts and washers to prevent taking the flywheel off.
[Edited on 27/7/10 by coozer]
big-vee-twin
posted on 27/7/10 at 11:53 AM Reply With Quote
Duratec on its side
Duratec to Type9 Bellhousing
http://www.triangleltd.com
