Author: Subject: Duratec/Type 9 Overall Length Needed
grassracer
posted on 27/7/10 at 06:44 PM Reply With Quote
Can anyone measure me the overall length from the front of the front pulley to the rear of the tailcase of a 2.0 Duratec and Type 9 gearbox combination, doesn't have to be mm perfect but to within a couple of cm will do, thanks in advance
big-vee-twin
posted on 27/7/10 at 07:12 PM Reply With Quote
1270mm
http://www.triangleltd.com
grassracer
posted on 27/7/10 at 07:28 PM Reply With Quote
Thank you very much now all I need is the height of the engine, base of sump to top of cam cover
[Edited on 27/7/10 by grassracer]
big-vee-twin
posted on 27/7/10 at 07:29 PM Reply With Quote
I'll go and measure then, mine has standard sump at present give me 5 mins
big-vee-twin
posted on 27/7/10 at 07:32 PM Reply With Quote
640mm including oil filler cap
Can I ask why you need these dims?
Duratec to Type9 Bellhousing
[Edited on 27/7/10 by big-vee-twin]
grassracer
posted on 27/7/10 at 07:35 PM Reply With Quote
Much appreciated, I have a space in a grasstrack car that needs an engine/transmission , the space is not flexible so engine choice is more to do with what fits as well as fitting the budget. Thanks very much
