Author: Subject: Type 9 gear lever
JeffJeffers
posted on 18/8/10 at 12:24 PM Reply With Quote
Type 9 gear lever
I'm having problems getting my engine and gearbox to fit my chassis.
On the type 9 gear lever there is a black bush half way down, what is it for and do I need it? Also would it matter if I bent the gear lever to some new angles?
Bluemoon
posted on 18/8/10 at 12:31 PM Reply With Quote
Bush stops vibrations. I think you could remove it. Yes you can bend the lever (common to do in the indy)
Humbug
posted on 18/8/10 at 01:13 PM Reply With Quote
Yes, you can remove it, but the rubber isolates the top and base of the gear lever, so you will be left with a short stump. I did this, then made a replacement lever using some steel tubing slipped over the stump, then filled it with a piece of threaded bar for strength, the whole lot fixed with Araldite Steel. It give me a lever about 5" long. I didn't need to bend my lever as it clears the dash anyway, but there's no reason why you shouldn't do it.
Re vibration: I haven't found any problem at all with my non-bushed lever.
posted on 18/8/10 at 02:13 PM Reply With Quote
I shortened mine by removing the bump and fitting the gearknob in its place - and found the lever too short!
I extended the stick a couple of inches with a sleeve and then found I had enough leverage for an easy shift.
The moral is - don't cut it too short!
JeffJeffers
posted on 18/8/10 at 10:32 PM Reply With Quote
Thanks for the advise.
I'll see if I can decide the best way to fit it.
