Author: Subject: Bike carb plumbing
Dickyboy
posted on 22/9/10 at 09:05 PM Reply With Quote
Bike carb plumbing
I have installed a set of carbs from a Yamaha FZR 600 on a pinto that seem to work OK (limited testing so far). But there are two outlets that look like overflow or fuel returns, question is what do I do with them?
[img]http://http://lh6.ggpht.com/_HYQZ1VqjSIA/TJpthvIy4hE/AAAAAAAAADk/5dNToYLM7FA/s144-[/img]
tony-devon
posted on 22/9/10 at 09:10 PM Reply With Quote
I cant see the photos, but guessing your talking about 2 T pieces between carbs 1+2 and 3+4?
the float bowls are vented, just fit some hose and run them down out of the way, unsure with cars etc for your IVA test etc if you would need a catch tank? but I expect someone else can advise on that
heavy is good, heavy is reliable, and if it breaks, hit them with it
Dickyboy
[img]http:// Description
[/img]
whitestu
posted on 23/9/10 at 07:02 AM Reply With Quote
They look like heater pipes to me.
my ZX6 carbs had them. If they are just take them off and ignore them.
Stu
SeaBass
posted on 23/9/10 at 07:25 AM Reply With Quote
Tony is right on this they are overflows from the float chambers. Best to vent them somewhere safe.
posted on 23/9/10 at 07:38 AM Reply With Quote
They certainly appear to be the wrong side to be vent tubes and the right side to be float chamber vents as said. What's wrong with a little petrol dripping onto a hot engine?
