the man with a plan
| posted on 10/6/04 at 10:19 PM |
Perhaps a stupid question?
I've just bought a 2l pinto lump and T9 gearbox off ebay for £5.50. I was wondering what the best method of transporting it would be? The
gearbox has been removed from the engine, which probably makes things easier.
Will i need to buy a hoist for moving it about?
200mph
| posted on 10/6/04 at 10:22 PM |
is liftable with 2 people, obviously the engine is a fair bit heavier
but 3 is probably recommended
Mark
the man with a plan
| posted on 10/6/04 at 10:34 PM |
One thing I was worried about was it knackering the rear shocks of my other car if i were to put it in the boot, and if so how to secure it to prevent
it denting the wings or causing other damage.
| posted on 10/6/04 at 10:42 PM |
It's not that heavy, three decent sized passengers would weigh more. The engine won't move far if it's on its side and the gearbox
will wedge in with it if you're in a hatchback. You'll definitely need a hoist to get it out with though.
the man with a plan
| posted on 10/6/04 at 10:45 PM |
Its a Saab 9000, so space should not be a problem.
Although needing a hoist to get it out, is one required to get it in?
bob
| posted on 10/6/04 at 11:09 PM |
Its a heavy old lump the pinto,i bruised some ribs lifting mine out the side door of a transit.
It would probably be easier in and out of a van,i put engine on an upturned pallet so it was trapped between the wooden legs for transporting.
the man with a plan
| posted on 10/6/04 at 11:20 PM |
I was thinking of buying an engine stand anyway for ease of rebuilding the engine if required, with this could I get it in and out of the back of an
estate?
btw, good plan with the pallette, bob
thanks
mangogrooveworkshop
| posted on 11/6/04 at 05:44 AM |
pinto alone is =- 115 2 120 kg gearbox is 25 2 30 kgs think.........but thats not the real problem.........its the oil that will leak out that will
trash the boot. best drain it or have a heavy sheet to contain any spills.
as for handling engine cranes are a good investment saving a lot of grief and accidents cost money....the engine stand is a must at 30 quid
[Edited on 11-6-04 by mangogrooveworkshop]
SeaBass
| posted on 11/6/04 at 07:15 AM |
Man with a plan, you really need an engine crane to install the engine on the engine stand. The stand will be of no use to use when trying to move the
Pinto in and out of a car. Also worth bearing in mind that to attach the engine to the stand you normally have to remove the flywheel to give enough
clearance when using the bellhouse bolt holes. I've seen people with the engine attached on the engine mount hole but this isn't ideal.
Mark Allanson
| posted on 11/6/04 at 06:41 PM |
As for getting it in or out, its got to be a crane or several willing volunteers. I found the best way of protecting the car is loads of old carpet,
chat up your local carpet fitter, he will be more than willing to let you take the stuff away
| posted on 11/6/04 at 06:44 PM |
the subframe from the front of the donor makes a perfect stand for the engine, though the sump will hit the ground until you chop it i think. two
pieces of wood wil raise it enough.
a frame and pulleys if the cheapest way to move engines reliably. you can throw one together for a few quid.
greggors84
| posted on 12/6/04 at 01:46 AM |
I wouldnt worry about the engine weighing to much for the car. I had to go a pick a mate up from stafford, then picked up a pinto from Jonty in stoke,
then on the way back (slight detour!) picked up 5 caterham 16" wheels and tyres. All in the back of a Rover 200 hatchback. Still drove fine,
just had to watch i didnt brake too hard other wise the wheels would have knocked us in the back of the head!
Chris
The Magnificent 7!
