jossey
| posted on 7/10/10 at 01:13 PM |
new lower steering column bearing. wowwwww
Just got my lower steering column bearing.
looked amazing.
:O)
Thanks to simplybearings.co.uk
Image deleted by owner
cheers
David J
[Edited on 7/10/10 by jossey]
sickbag
| posted on 7/10/10 at 02:09 PM |
These bearings seem to be the way forward - have you got the part number? Going to replace my current arrangement for one of these.
Finally back on the job!
jossey
| posted on 7/10/10 at 02:46 PM |
100% better than the one off the donor car!
hope that helps.
SBPFL205-16 Oval 2 Bolt Pressed Steel Bearing Housing with 1 inch insert = SLFL1
looking forward to installing it and getting my steering fully working.
i do like this one as well as this maybe better for mounting to the chassis but the other is the direct replacement for the Ford one.
ill upload photos when installed.
SBPP205-16 Pressed Steel Pillow Block Housing with 1 inch Insert
Dave
40inches
| posted on 7/10/10 at 04:21 PM |
I done that
  fitted to bulkhead
jossey
| posted on 7/10/10 at 06:31 PM |
good work 40" love it.
:O)
come do mine for me :O)
dave j
hobbsy
| posted on 7/10/10 at 06:41 PM |
Why does you steering not work with the normal bushed setup? Ok they wear eventually but have you felt the weight difference? Are you the angles all
wrong on your column or something? I don't understand why it requires a big heavy bearing just to "work"?
Breaker
| posted on 7/10/10 at 06:44 PM |
Interesting site ! Do you know they also supply bearing kits for sierra wheel hubs ?
Surrey Dave
| posted on 7/10/10 at 06:47 PM |
Karts
In my day that was a kart rear axle bearing circa 1970's
40inches
| posted on 7/10/10 at 07:15 PM |
A lot of people have had binding problems with the Sierra setup, and in some cases stopped the steering self centering
The bearing is 25mm, not that heavy, and it does make the steering a lot lighter and smoother.
steve m
| posted on 7/10/10 at 09:44 PM |
Nice invisable steering column
Is is sva/iva compliant?
