Author: Subject: LED stop/tail
Breaker
posted on 15/10/10 at 11:51 AM Reply With Quote
LED stop/tail
SVC sell these double working stop-tail lights.
http://www.s-v-c.co.uk/prod/U-Bright_outers.html
Basically the outer ring works as tail light and as stop light. Is this IVA OK ?
loggyboy
posted on 15/10/10 at 11:53 AM Reply With Quote
E marked = IVA ok IIRC
Howlor
posted on 15/10/10 at 11:55 AM Reply With Quote
I was pulled up for this as it stipulated that the brake and tail had to utilise a separate circuit/filament. This may have been an SVA testers interpretation of the rules but I had to change them to standard bulbs for a pass.
loggyboy
posted on 15/10/10 at 12:00 PM Reply With Quote
IIRC they have 2 circuits, one set of bulbs for tail and nother for the brake, but dont quote me, i reval seeing them in action at SVCs stand at detling. Worth a call to them, they seemed quite helpful at the show.
blakep82
posted on 15/10/10 at 12:15 PM Reply With Quote
they are completely seperate. the outer ring does one thing, the inner does the other, and they can be seperated
i'm worried now though, coz mine are LED, and the LEDs are a certain brightness for tail lights, and the same LEDs get brighter when the brakes are on... they're e-marked though
________________________
Breaker
posted on 15/10/10 at 12:43 PM Reply With Quote
No, the outer ring acts as tail and stop light.
[Edited on 15/10/10 by Breaker]
blakep82
posted on 15/10/10 at 12:45 PM Reply With Quote
sorry, yeah, read it wrong. if they're e-marked, they will be fine
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 15/10/10 at 12:50 PM Reply With Quote
Mine are exactly those and I passed SVA fine. The stipulation is that a bulb cannot share the same function though it is not a problem for LEDs.
Breaker
posted on 15/10/10 at 01:02 PM Reply With Quote
The guy from SVC just told me that the tail and stop light share the same LEDs. They just get brighter if you press the brakes. Still IVA OK ?
loggyboy
posted on 15/10/10 at 01:54 PM Reply With Quote
I cant find anything in the manual relating to seperate circuits or filaments.
posted on 15/10/10 at 03:54 PM Reply With Quote
<< Passed SVA with those, no questions.
posted on 15/10/10 at 04:59 PM Reply With Quote
No we didn't, the LED outer rings on ours are tail lights only.
Breaker if you're unsure, just get on the phone and speak to Steve at SVC
Phil
LBMEFM
posted on 15/10/10 at 08:34 PM Reply With Quote
Got them on mine, passed SVA with no problem. Barry
martyn_16v
posted on 16/10/10 at 07:35 PM Reply With Quote
My tester was quite happy with them just last week
