Daddylonglegs
| posted on 28/10/10 at 08:49 PM |
Cooling Pipes
I'm in a bit of a quandry. I really want to get a crack on and at least get the engine running so I can give myself the incentive for the final
push towards completing the car.
The problem is, I have a Pinto fitted and the radiator is non-Pinto, I think it was from a Polo or similar. I have been trying to figure out the best
way to connect the radiator to the water pump and thermostat housings. I have managed to find some hoses at shows and the one shown below is hopefully
OK.
  Top Hose
My question is, does anyone think that the kink in the top hose will cause a major issue? I did think of wrapping the hose with a largish spring to
prevent the kinking (a bit like an external version of the ones used for bending copper tubing).
Also, what will be the best way to connect the bottom hose? The ringed hoses in the picture below are the ends that need connecting.
  Bottom Hose 3
The ID of the hoses are approx:
From water pump - 32mm
Radiator bottom hose - 21mm
Any help gratefully received.
Cheers.
John
RichardK
| posted on 28/10/10 at 08:52 PM |
I've got some hoses that I just pulled out from my pinto, you want to have a look through my gallery to see which ones you want?
Rich
Gallery updated 11/01/2011
Daddylonglegs
| posted on 28/10/10 at 08:58 PM |
Hi Rich,
Can u put up a link? I found some hoses but they seem like lengths of new stuff. You've got a lot of piccies to trawl through and my internet
ain't the quickest
RichardK
| posted on 28/10/10 at 09:04 PM |
I've got all the hoses that cooled my pinto really well, I will have to check to see which hoses I'll need to keep for my zetec (if any)
maybe we can work something out? Theres a new blue 90 degree reducing bend at the bottom that you cant see feeding the lower rad.
Rich
Daddylonglegs
| posted on 29/10/10 at 07:11 AM |
Cheers Rich.
The one at the top will be no use because my radiator exits on the offside, but the lower one may be OK (from the water pump to the lower radiator
connection) as long as the connection to the radiator is the same.
Also, what is your view on the slight kink in the top hose in my pictures?
JB
pewe
| posted on 29/10/10 at 11:09 AM |
See Merlins selection of Samco hoses - all ex-stock.
Not partic. locost but if needs must....Merlin Motorsport
HTH.
Cheers, Pewe
| posted on 29/10/10 at 11:25 AM |
I wouldn't worry about the kink, the water pressure will soon open it out again!
As for the bend I'd chop the one on the right back to where it's "straight" and either use a simple (and easily available) bit
of silicon hose and some joiners or (if the I/D of the hose was suitable) make up a piece of bent copper pipe to the right angle / shape.
blakep82
| posted on 29/10/10 at 12:15 PM |
HTH.
Cheers, Pewe
look for venair hoses on ebay. good quality, and cheaper than samco
________________________
