Author: Subject: My Best Option?
the man with a plan
posted on 14/6/04 at 10:41 PM Reply With Quote
My Best Option?
Hello,
I'm looking to build myself a McSorely +442 chassis, running a Pinto 2l + T9 box (both of which I (almost) already have). Preferably I want a live axle setup.
What is my best choice or choices as a donor for front and rear hubs, steering rack, rear axle, prop shaft and pedal box? I am not overly bothered about having a Q plate and so am prepared to take all the bits and bobs from different cars down the scrappie, hopefully with little or no mods.
Thanks a lot
DavidM
posted on 14/6/04 at 11:58 PM Reply With Quote
I'm assuming a McSorley +442 is 4 inches wider, 4 inches longer and 2 inches higher. If so it seems to me that you need a mark 4/5 cortina. That'll have all the bits you need in a single donor with a +4 live axle.
the man with a plan
posted on 15/6/04 at 12:51 AM Reply With Quote
Yes you are correct about the dimmensions.
What adjustments, if any, need to be made to the steering rack, front hubs, and suspension wishbones?
Does anyone know if using the rear axle (with diff and hubs), and the front hubs and rack from a single car, but not the engine and box, will be enough to obtain an age related plate?
Thanks a lot.
type 907
posted on 15/6/04 at 06:11 AM Reply With Quote
Hi
Is a McSorely chassis +4 at the nose?
If so an Escort rack is almost perfect
from a bump steer point of view, just
needs rack extensions on the ends.
Book dims are fine for w/b's.
This is assumeing you go for Cortina U/R's
See my photo archive.
Hope this helps.
Paul G
Too much is just enough
DavidM
posted on 15/6/04 at 11:31 PM Reply With Quote
Don't know, but I seem to remember previous posts relating to this. Try a search.
Mk-Ninja
posted on 16/6/04 at 07:56 AM Reply With Quote
Try this
http://locostbuilders.co.uk/viewthread.php?tid=14192
I'm sure I've got one, just don't know where I've put it
